Loud clunk when i go over a bump
Last knight i took the 930 out for a rip in the smoke filled california mountains, (nothin new) and every bump in the road the right front clunks,the 930 is loward but its been lowered for 20 years.
Sent from my SM-N910T using Tapatalk
Old 07-02-2016, 12:08 PM
any thoughts
Old 07-02-2016, 12:10 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Kevin, the sounds you hear while driving are usually very misleading with regard to their location, and "usually" a thunk sound over bumps is something to do with the rear anti-roll bar - maybe one of the bolts from a drop link is missing and allowing the bar to hit the underside of the tub when it moves, or possibly one of the bar mounts has pulled away (broken off) from the underside of the tub (both are common problems) - check that out first.
Old 07-02-2016, 12:37 PM
I got her on the hoist and i am findind everything is in tact,the only thing that is loose is the esentric that sets ride height,but it would seem that once the car has a load that should be tight.
Old 07-02-2016, 12:50 PM
Non User
infraredcalvin's Avatar
On the front, check the bolt at the top where the strut mounts to the fender, if tight, check underneath the cover that the shock insert itself is tight in the strut housing.
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 07-02-2016, 03:14 PM
Thanks,i will do that.
Old 07-02-2016, 03:56 PM
930T Owner
Hams930T's Avatar
Side bar but the underside of your car is ridiculously clean. I just wanted to note that observation.
Well done!
Chris.
Hams930T
2017 Turbo S
Old 07-02-2016, 06:41 PM
Check the jack in the front of the car and see if the rubber strap is still holding it snug in place.
The bottom of your car is cleaner than new!
There's a roll pin in the bottom part of Bilstein struts that holds the end of the insert in place. Maybe it's gone wrong but everything under there looks so nice...
Old 07-02-2016, 09:51 PM
also check the sway bar drop links with the car on the ground. check for play, if they move , I would tighten one of the drop links to take up some the play, those hime joints sometimes make a clunking noise, that's what happen to me
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 07-03-2016, 01:41 PM
Forced Induction Junkie
WERK I's Avatar
Is your battery hold-down secure?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 07-03-2016, 02:35 PM
Battery is tight,roll pin is in on the bottom of the strut,the two 8mm bolts that go through the thick bracket that sit ontop of the strut tower were somewhat loose.I tightenedbthem and took her home,but that did not solve the thunk.I am back at the shop putting her back on the ho ist to see if i missed anything.Heliops2 i am checkin that now.Thanks guys/gals for all the help.Its only clean under there because all the grime is on my arms and face.HaHa
Old 07-03-2016, 03:50 PM
kevin,
Check the bushings where the front antiroll bar penetrates the front inner fender. If there is excess clearance with the bar, it will make a clanking noise.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 07-04-2016, 08:07 AM
WERK I's Avatar
How old are the front A-Arm bushings?
Dave
Old 07-04-2016, 08:52 AM
One other thing to check is the rear sway bar mount to the chaises, I had the same setup on my old yellow 911gt , the weld broke on the rear mount... I also had the front sway bar break, you can see it from the frunk near the fuel tank...
1992 964 C2 turbo
Old 07-04-2016, 11:31 AM
Mr9146's Avatar
Check to make sure the shock insert bushing in the strut isn't worn out. That'll give you movement that knocks...
Old 07-04-2016, 03:28 PM
full quack's Avatar
Send a message via Yahoo to full quack
I'll second the rear sway bar mount{s}, I broke mine on both sides within 2-3 months of owning the car. Sticky tires and hard driving will kill the wimpy rear sheet metal mounts. They start to crack then give up the ghost in short order.
Easy eyeball check, you don't even have to jack up the car.
Mark
Old 07-04-2016, 03:47 PM
Originally Posted by full quack View Post
I'll second the rear sway bar mount{s} . . .
Mark
Actually, Dubs, that would be thirding the bar mounts, as I suggested that in post number two and Kevin stated that he has checked them out already. You and Helio are a couple of no-post-reading chowder-heads!!!
Old 07-05-2016, 10:50 AM
Probably the jack loose and rattling around in the front right corner of the tub... it's real common. Rubber straps don't last forever.
I wonder if he checked that yet.
I modified an old SC air cleaner housing rubber strap I had to hold mine snug in place.
Old 07-05-2016, 11:39 AM
J man i took the jack out so i know its not that the rubber strap although its still there its almost torn in two.Mark my sway bar mount torn from the pan on dr-side i rewelded and seems my cruddy welds are holding.
Old 07-05-2016, 05:00 PM
Rawknee,when i smack the bottom of the tire i can feel a vibration and i do the samething on dr-side there is no vibration.I checked movemet back and fouth thinking wheel bearing but no play.Only up and down
Old 07-05-2016, 05:09 PM
