wasted spark COP with EDIS6 module
Looking for a way to run coil on plug(wasted spark) with the EDIS6 module. I have a Microsquirt v3, and currently run standard EDIS6 with the coil pack. I have found bits and pieces of how to do this, but not sure exactly how to do it. I just want to get rid of the big coil pack, with all of the wires running around the engine bay. Here is what i can gather.
1. Using 2 EDIS6 modules. I assume you just wire the modules in parallel with each other, then just use 1 channel from each output to run 1 coil pack? 2. Using 1 EDIS6 module, and wiring the opposite coil pack in series? I know it has been done before, but there just isn't any information(that i can find) to make this work. I would love to use the Denso Kawasaki motorcycle coils. If anyone can give me some insight on this, that would be super helpful. |
Adam ( no carrier) is out of town till Monday. He is currently doing that but with ms3 pro
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp |
Bland
I ran MegaJolt on my 73 911T Chumpcar.
The megajolt was slick because you get 2 10x10 ignition maps you program with load vs RPM and you input an advance number. I has the 'stock' and RS curves and you could switch between the 2 with a toggle switch on the dash. I pulled the wiring harnes out of a Ford ranger so I had factory shielded wires. I also used the EDIS6 box from the same truck. For the crank trigger, I got a goingsuperfast crank pulley off of eBay an their pickup mount. They include a plug for the distributor hole. I used a coil pack from a Dodge minivan because Ford had oddball ends on their plug wires. I still had to modify the Porsche wires so I was no further ahead. The challenges I ran into: the GSF crank pulley required a bit of grinding on the mag case of a 2.7 to fit. The belt size for this pulley took some trial and error to sort out. The system took under 4 hours to install (clearancing the case took some time). It was super reliable, and gave good power on a 2.7 with modified Zenith carbs. For load, you can go with throttle position sensor or manifold pressure. I went with maf. I used the ports on each of the zenith barrels and ran lines up to a vacuum pot with on line leading to the maf sensor in the megajolt box. https://www.autosportlabs.com/product/megajolte/
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche Last edited by unclebilly; 04-15-2017 at 06:02 AM.. |
I actually just found a thread where a guy had a lexus V8 engine running COP with 2 EDIS8 modules, and it worked well. I think i am going to try another EDIS6 module with the Kawasaki Ninja COP coils, i will run 1 bank per EDIS module.
Chain fence eating turbo
Join "MegaSquirt Addicts" on FB. Your answer will be given within 5 minutes.
I rather you have a board made and ditch those modules IMO... |
Bland
That's awesome. For a 6 cylinder, would you run 2 EDIS 6 boxes?
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Bland
What does COP give apart from higher RPM and cool factor?
I'm going to go this path again on my next 2.7 build and have been contemplating twin plug and high compression.
Beauty of COP is not having nasty plug wires. |
I have been more than happy with the Microsquirt, it does everything i need it to do. i doubt i will ever need anything else, BUT you never know.... |
For those wondering, I got another EDIS6 module, and wired the VR sensor, and SAW in parallel. I bought 8 used denso pencil coils for $40, and used 2 ignition harnesses from a CBR929. For a total of $65, I did a wasted spark coil on plug set up. I should have my transmission back together this week, and the driveline back in the car this weekend, so I won't know if it's a success until this weekend
Just in case someone is following this post, or for future reference. I finished up the car today, and the car started right up with the wasted spark COP set up. No changes to tunerstudio, nothing. Runs great. It is probably the most simple way to go COP. $65 in used parts got me everything i needed to do this conversion.
This looks pretty cool. I'm using a microsquirt 3 already to control the fuel with the lambda valve, I'd love to add fully programmable ignition as well, and this looks like an easy way to do it. Can you tell me the part #'s for the coils, and which plugs you're using? Also, are you driving a factory tach with the microsquirt? How so? Cheers Last edited by flightlead404; 04-30-2017 at 06:17 PM.. |
I used the Denso 129700-3880 coils. They come on several different motorcycles from the mid 2000s. I am using just the standard BPR7ES plugs. You have to screw the tips off of them to make them work with the motorcycle coils.
On the tach, i just connected the microsquirt Tachout wire and hooked it up the tach signal wire that is attached to the factory harness. the EDIS module also has a tachout wire that you can hook up alternately. Quote:
I'm having the devil of a time finding that Denso part also. Plenty of 129700-xxxx but no 3880. Any idea what year/vehicle? How is the fitment, are they flush with the valve cover, reasonably snug etc? I've been reading that some of the EDIS modules have built-in 6,300 rpm rev limiter, any issues with that? Last edited by flightlead404; 05-04-2017 at 08:42 PM.. |
The coil packs came from a 2001 Honda CBR 929. the last 4 digits are the length from what i understand. I believe you could go a little bit shorter. mine stick out just a little bit. I have my rev limiter set to 6750rpms, and just looked back on some datalogs, and it confirms that i have been running up to 6750rpms. I wasn't aware of the 6300 limiter, but after looking, there are many confirming just that. The modules i have been using is out of a early-mid 90s ford ranger/explorer.
Thanks for the info.
I'm struggling now with if there's another way to do COP with the Microsquirt V3 without the EDIS modules, and be able to mount everything where the current CDI box is now. EDIS has the benefit of being a little simpler (crank sensor only no cam sensor needed) and has the limp home mode, but on the other hand doesn't support some advanced things like the various spark cut or retard modes for rev limiting, launch control etc. I'm going to have the engine out to put on the crank pickup and new cams so adding a cam sensor probably isn't that big a deal to do at the same time. |
unfortunately you can only run sequential ignition with Microsquirt v3 on a 4 cylinder engine.
I am pretty sure you can use the EDIS for some advanced things, I am using spark cut for my rev limiter(i think), I dont know about launch control. It seems that you are close to outgrowing the microsquirt. May be time for Megasquirt 3 Pro. You may be able to use 2 quad spark modules and do away with the EDIS, or maybe a Bosch 3 channel ignition module? The EDIS modules fit quite well where the stock CDI box used to sit. I think Nocarrier posted up a pic of his set up with both edis modules in the stock location. Quote:
935 Suspension with Moton Coilovers for the street You can usually find low mileage used coils on Ebay.
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
