Originally Posted by T77911S View Post
chris,
if you could only do one mod at time what would be the order. (not to go OT as this may interest the OP).
twin plug
cams
a true header like rarely8 header.
I have headers, exhaust, upgraded turbo, and will be doing cams and clutch this winter along with probably EDIS+COP ignition driven by Microsquirt v3.
Based on what I'm hearing its worth doing the twin plugging if/when I yank the heads to do p's and c's.
Old 05-10-2017, 09:21 AM
T77911S's Avatar
i agree. would love to twin plug.
for me its not so much the work and machine work, its the ignition sys.
I have a "header", 7006 and RUF IC but would love a true header, cams and twin plug.
also trying to get a perspective of the upgrades from someone that really knows the facts of the upgrades, chris.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-10-2017, 09:48 AM
Way back in the mid eightees IMSA was changing rules to try and slow down the Porsche 962 because it was winning every race again and again. They made the 962 run with more weight to try and slow it down.
The cars came with Titanium nuts and bolts throughout the chassis so they were removed and steel ones installed in place of them to increase weight. That wasn't enough so next IMSA forced them to install a 70 pound lead weight on the floor to the left of the pedals and drivers feet. Then IMSA told Porsche to remove the twin ignitions and dual plugs and go back to single plugs to try and slow them down.
I don't remember what else they might have done but two valve engines do run a little better with twin plugs then one off center single plug.
I have an old 980CC BMW twin cylinder air cooled motorcycle with dual ignitions and dual plugs. It's sort of like half a Porsche 356 or 912 motor.
If I pull one spark plug cap off one of the cylinders while it's idleing at 800 rpms so it goes from dual plug ignition to single plug ignition the motor slows down a little.
Old 05-10-2017, 10:17 AM
Ollies930's Avatar
Since squish was mentioned earlier and JFairman mentioned the later IMSA 962s, if you look at one of those later 962 cylinder heads, they actually have a lot of material added to the combustion chamber opposite the spark plug, in an effort to speed up the combustion by adding turbulence via squish. Not sure how well that worked compared to the twin plug set up, but there is a nice picture of one of these heads in Bruce Andersons book.
Old 05-10-2017, 10:24 AM
16Volt's Avatar
Love this discussion.
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 05-10-2017, 10:26 AM
Ingenieur
Well, the 3.0L 962 never had twin plugs because it was a four valve engine. As far as pulling the plug, you effectively retarded the timing when you did that, so of course the rpm went down.
There is no magic. Physics rules. There is only a 2 to 4 percent gain to be had, strictly from the shorter combustion duration. Every Ruf CTR2 is making 700HP with a single plug.
Old 05-10-2017, 12:02 PM
Ingenieur
I was actually thinking of that. I know people weld aluminum heads to repair them. I wonder if you could build a squish area up without hopelessly distorting the head. You could do a 95mm bore with 6 CR 930 pistons, and bring it to 8 CR with squish area.
Old 05-10-2017, 12:09 PM
Mike Billings's Avatar
Bathtube combustion chambers
Thanks Burn Bros
07 911 Turbo - Pilot Sport Cup 2 ZP
96 Carrera 4 - Toyo R888r
73 911E - Hoosier R7 + twin 75's
92 Corvette - Nitto NT01
14 BMW X3 - Pilot Sport A/S 4
Old 05-10-2017, 12:21 PM
Well, I used to do some fiberglass repair and body work on Preston Henn's Swap Shop 962 chassis number 962104 (it was the fourth one made) back in the mid eightees when it was racing in the Florida IMSA races and it was not a 4 valve DOHC motor.
It was an air cooled single overhead cam two valve per cylinder 962 motor with Motronics.
The 4 valve 962 motors came later. If I remember correctly they had water cooled DOHC 4 valve heads and air cooled cylinders.
Old 05-10-2017, 12:25 PM
TurboKraft's Avatar
chris,
twin plug
cams
1. Cams
2. Headers (not those)
3. Twin plug
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 05-10-2017, 12:32 PM
TurboKraft's Avatar
A lot of development is being done in that area right now.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 05-10-2017, 12:34 PM
Chain fence eating turbo
TIG should mitigate warpage. But, seems like you'd need to bring everything up to hot to relieve the stresses of welding once done building up material?
Old 05-10-2017, 01:13 PM
Or you could go with an Xtreme head casting and carve your own combustion chamber....
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 05-10-2017, 03:22 PM
That would be sweet!
Old 05-10-2017, 04:04 PM
Ingenieur
I think you're right Tippy. The link Mike Billings posted shows that it can be done. I am seriously thinking about doing this, especially since I have a victim for this project:
Less material has to be adddd for us, probably a lot like the 956 head Ollie mentioned, since we need a CR in the nrighborhood of 8.
Old 05-10-2017, 04:55 PM
Ollies930's Avatar
Keep in mind that when welding up a combustion chamber, no matter how careful you are and how much you preheat the heads, you will need to replace the valve seats, as they will loosen up and the heads will need to be resurfaced. Not a big deal, but be aware of the extra cost.
Old 05-10-2017, 08:37 PM
jwakil's Avatar
Funny, just saw this thread, and a few hours ago I happened to have Waynes 'Modifying 911 Engines' book on my desk and happened to open to a section on Twin Plugging. He says you won't get much benefit in performance unless your compression ratio is greater than 10:1. There are other benefits however.
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 05-10-2017, 09:11 PM
Jonny H's Avatar
You get a significant power improvement with twin plugs because they solve the problem of the flame propagation being interrupted by the piston dome.
We have found that rapid multi-spark has a similar effect, provided the second spark is suitably timed to follow the first (the sweet spot being around 400us for CDI+). We believe that after the first spark, unburnt turbulent mixture moves into the path of the second spark where it is ignited.
It certainly shows on the combustion analyser and the AFR shows leaner. Like you say, the effect is more noticeable on the early 911s with domed pistons. Typically, a '69S will see gains of 6 ft lbs across the board.
www.classicretrofit.com
Old 05-12-2017, 03:26 PM
Will be watching if you do so!
Old 05-12-2017, 05:30 PM
Great insight!
