Hi all I have decide to get rid of the distributor and install COP .. coil on plug...system ... does anyone make a kit for this or does it have to be made up from several suppliers...
Chain fence eating turbo
I believe Turbo Kraft and Clewitt do in the USA?
I put a pair of M&W CDI's, a set of twelve COP's and a full set of spark plugs on my twin turbo 930 engine - all sourced from Chris at TurboKraft. I control the CDI's with the output from a Haltech ECU.
The TurboKraft ignition system has performed flawlessly for the past 2 years and solved all of the problems that I previously had with the AEM / COP system. Based on my own experience - Ignition is an area where trying to save money is foolish on these cars. You cannot go wrong following Chris's advice in this area. Richard.
RSR Replica - http://forums.pelicanparts.com/porsche-911-technical-forum/472762-rsr-update.html 930 Cab - ex-IA car, 3.4L, 1.2 bar, G50 996 Turbo - X50. |
Hi,
You'll want to run a pair of M&W Pro-16b CDI units. They're made in Australia, simply the best we've ever tested. They'll be triggered directly from the ECU. COP units: we've got some really low profile ones that fine great, easy to get out for plug changes when the engine is in the car. We usually use the RSR-style plug hold downs to keep them in place "just in case" even though we've never had one fall off a lower plug. Plus they look period-correct and cool. 12x COPs + connector kits + spark plugs = $1128 12x RSR plug holders with hardware = $204 More than enough spark to support 800rwhp.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
E-85 sippin drunk
I can vouch for the M&W CDI unit. Definitely, a top quality piece.
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Hi Chris I am only running single plug plus I already have the Autronics Direct fire CDI 500R
and also have the spark plugs .. so I would like to order 6X COP units plus+ connector kits and mounts could I also grab a T-Shirt in small and a couple bumper stickers Please include postage to Sunshine Melbourne Australia 3020 Regards Paul Duggan |
Paul, thank you, will reply in email.
Slantnose from HELL
How or better Q... Where, do you mount the two M&W CDI's?
It changes from time to time..... |
A couple of different ways -- sometimes on the engine, but usually on the engine compartment wall and covered by the original plastic relay panel cover.:
Slantnose from HELL
Very clean installs as usual. I am contemplating an ECU upgrade and go COP's. Very much appreciate the pics and info. I need to drop the engine for a clutch change and it might be the time to do it.
Thanks. We probably had just run out of zip-ties and had to think of something...
![]() We love the bulletproof performance of the CDIs, ease of tuning, running a slightly colder plug than normal with no concern for fouling if just driven on the street.
