Part number help please AAR hose
I have looked but I get distracted easily and have not been able to find the part number for the hose that goes from the AAR valve to the intercooler. Can someone please identify the part number for me?
89 930 Cab Black 11 Cayenne |
Administrator
Hi Mike - if our members don't get back to you with the part #, feel free to give us a call at 888-280-7799 and one of our Porsche part specialists will be able to help you out.
Thank you I got the number I will order it soon
Work in Progress
Looks like it is part 999-239-009-40.
Rubber Hose 99923900940 - Genuine Porsche - 999-239-009-40 | Pelican Parts If I'm correct about the dimensions Pelican gives it appears to be a 27mm outside diameter - 18mm Inside diameter hose. 18mm is about 3/4 inch, so maybe you can just get some standard 3/4 inch hydraulic hose and that could be a cheap replacement. I'd check the inside diameter before I went buying anything though. If you need me to pull my hose and check the inside diameter I can do that. Cheers Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
Derrick |
Mighty Meatlocker Turbo
Definitely a brother from a different mother! ![]() Mike, heater core hose works perfectly there (is thick walled, so holds shape nicely and does not kink - though there is noting wrong with "kink", buttofcourse! ![]() |
Thread Tools | |
Rate This Thread | |
