jbrown's Avatar
what tranny
I have a 3.5 l turbo EFI with a short bell housing 4speed turbo tranny in my car right now. Was thinking about swapping over to a 5 speed tranny, I know most of them work with hydraulic clutch. What tranny and what is the going rate to do the conversion.
If I do this I do have a nice short bellhousing 4 speed turbo tranny I would sell.
Thanks John
83 sc cab turbo widebody. 3.5 liter supertec motor, B&B headers, EFI electromotive TecGT, TurboKraft GT35R billet turbo, 964 cams, WM inj, Bell full bay intercooler, Short bell housing turbo 4 speed tranny, roll bar, hargett shifter,
Old 03-14-2018, 06:34 AM
Chain fence eating turbo
You're wanting a G50/00, 01, 02.
You'd need the G50 pedal cluster I assume with the clutch master cylinder? Then the clutch slave cylinder and hose.
Beware the clutch master cylinder feeds from the brake master cylinder reservoir.
Chris as Turbo Kraft has a good Sachs clutch I believe for the G50 that's supposed to hold a lot of power and has an easy pedal.
I'm using a KEP Stg II pressure plate ($750) and Kevlar disc (California Clutch - $250) that's supposed to hold up to 650ft/lbs.
But, my pedal is pretty tough. Sucks in stop and go.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 03-14-2018, 07:12 AM
Beware too, the G50 weighs I believe 30 to 40 more pounds.
Also too, you may want a Patrick Motorsports billet diff cover. The G50 series of 00/01/02 have thin cast diff covers that can deflect under high torque which allows the ring gear to move away from the pinion gear resulting in metal gear soup.
I've never busted mine nor seen any signs of deflection, but apparently it has happened.
Old 03-14-2018, 07:15 AM
kevinbodman930's Avatar
If you do decide to switch to the g 50 maybe you can let us know how much of a difference it makes.
Old 03-14-2018, 10:17 AM
Based on the topic I expected to see a picture of Rawknee. So disappointed.
Derrick
Old 03-14-2018, 12:45 PM
Oh Tranny I get it..
Old 03-14-2018, 01:02 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
You two chowderheads need to check your PMs - butt only when family is not around!!!
Old 03-14-2018, 02:16 PM
I would check around to see if you habe to change your torsion bar tube to a g50. Tippy's car is ag50 car. What up Tippy!
Old 03-14-2018, 04:19 PM
Doh, you're right John. Forgot that huge detail.
How's it going?!
Old 03-14-2018, 05:00 PM
What up Tippy!
Originally Posted by Tippy View Post
How's it going?!
Forum hookup going on up in here!!!
Old 03-14-2018, 05:21 PM
Neighbors
Old 03-14-2018, 09:11 PM
Neighbors
Dat's nasty!
Old 03-14-2018, 09:51 PM
jbrown's Avatar
Thanks guys for all the replies.
I am in the process of putting a new clutch in my car and was thinking of next future project to change the trans to a 5 speed. I have the short bellhousing now and see they are worth some money. If I could off set the price of the conversion with selling my trans, I would think about it in the future. By the way Tippy everything is wonderful lol.
Old 03-15-2018, 05:55 AM
gearhead
While desireable, your short 930 is worth roughly half what it will cost you to convert.
And Raw Knees is the cutest tranny I know.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 03-15-2018, 06:24 AM
These G50's are getting hard to find and pricey,
CMS Rebuilt G50/01 SBH w/LSD+Billet diff cover - $11,500
There was a bone stock one that was $7,500 not to long ago, but it will also need the bell housing shortened (more $) to fit in your car.
The pedal assy. seems to be over 500.00 if you can find one, so maybe more.
I would guess you 930 box is about $5,000 so yeah, you would at best be maybe half way there by selling you trans.
Old 03-15-2018, 07:41 AM
jbrown's Avatar
Not sure if they are selling but I cant find a short bellhousing for less than $9000-$10,000...
Old 03-15-2018, 07:45 AM
gearhead
This is a steal:
911/930 Turbo G50-52 Transaxle
Short 930 is worth $5-6k.
1974 914 Bumble Bee
2009 Outback XT
Old 03-15-2018, 10:30 AM
Originally Posted by Matt Monson View Post
This is a steal:
Yes, the holy grail.
Old 03-15-2018, 10:39 AM
jbrown's Avatar
This is a steal:
Not that I am trying to sell mine but point me in the direction to get a short bellhousing for that price .... I have not seen one for that price for like 10 yrs...
Old 03-15-2018, 11:14 AM
JB, buy that -52!!
That 3.15 1st gear is far more useable than the -00/01/02 3.50 1st gear.
Old 03-15-2018, 11:54 AM
