gumba's Avatar
Xdi spark plug gap?
Recommended spark plug for a single plug Electromotive xdi set up. Using Bosch w3cs plugs?
thanks.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 04-27-2018, 10:06 AM
Stock Street Engine 0.045”-0.060” (1.1mm-1.5mm)
 High Performance Street 0.030”-0.035” (.75mm-.9mm)
 Alcohol High Compression 0.025” (0.65mm)
 High Power 75 -115 HP per Cylinder 0.025” (0.65mm)
 Over 115 HP per Cylinder 0.022” (0.55mm)
 Over 12:1 CR or Over 14psi Boost 0.022” (0.55mm)
http://electromotive.com/wp-content/uploads/2015/05/XDI-v1.7.pdf
Old 04-27-2018, 10:34 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Been running the F4CS plugs at .024. same thing as the W4CS but with the difference of having a 5/8 hex instead of a 13/16 hex. Makes it easier when changing them. More room. On your next set buy F3CS. You should be able to get away with .028 at your power level.
It changes from time to time.....
Old 04-27-2018, 12:19 PM
