Work in Progress
Dumb wastegate question
I feel like an idiot asking this, but what are the advantages of switching to a non-stock wastegate IE tial?
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
BLING and probably more options for spring rates
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp |
Easier to find replacement parts down the line too
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
Less weight, smaller package, larger diaphragm with less boost creep, and tunability.
Tonger |
I switched to a Tial when mine developed a leak. While it is true that its smaller and it does weigh quite a bit less than the original, there are no performance gains to be had by switching.
I’d look for other areas to improve on. Unless you have existing issues with your waste gate or you need to change the spring rate.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Work in Progress
Thanks guys.
I was just curious about why people do it.
I switched from the factory wastegate because the G50 conversion pushed the motor back just far enough that the headers wouldn't let the factory item clear the body (930 transplant, 911 shell).
Tial F46 was the easy fix for me; bolt-on replacement, fitted into the space available. But rebuildable, made from better material, more spring choices, smaller, lighter, cool colors- those are all good reasons too ![]() Ddin't realize the F46 was originally made for the 962, that's kinda cool too http://tialsport.com/index.php/tial-products/wastegates/42-f46]TiAL Sport - F46
'77 S with '78 930 power and a few other things. |
Turbo smart makes really good waste gates and bovs
Buy this guy some vacuum hose, he nailed it!
Ole Skool - wouldn't have it any other way |
^^^ Make sure it’s Silicone hose.
![]() Sent from my iPhone using Tapatalk
Derrick |
