DSPTurtle's Avatar
Originally Posted by 911pcars View Post
A reduction in vehicle weight should be measured in ounces, not grams.
1 oz = 28.3 grams
Replacing steel fasteners with Ti versions is for those with burgeoning DIY budgets and or bragging rights, and best suited for cycle weenies where weight savings can make a difference. Spend your money elsewhere for more effect.
FAQLoad - Bolt Tuning - replacing heavy steel bolts with titanium, aluminum and carbon fiber
Sherwood
Bragging rights it is. Those carbon bolts sound epic!
Old 11-26-2018, 06:02 AM
Chain fence eating turbo
Originally Posted by DSPTurtle View Post
I don’t think you’d be that worried. There are at least three fasteners for each critical joint. So it would be hard to miss if they started to fail.
Nylon:
https://www.mcmaster.com/standard-hex-head-screws
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 11-26-2018, 06:52 AM
911 tweaks's Avatar
+1 what Sherwood says....
If you are doing this for appearance that’s fine and a lot more cost effective to replate the hardware in finish of your choice and retain strong steel hdwr.
IF trying to reduce car weight, TONS of places to do and a lot more cost effectively achieve such...
Have fun... many ways to skin the cat you seek to do
I live for 911 tweaks...
Old 11-26-2018, 03:54 PM
KTL KTL is online now
Schleprock
KTL's Avatar
As long as you're chasing weight loss on the engine, get yourself a magnesium case breather cover and magnesium upper valve covers? The upper valve covers will typically require some flattening on the grinder table..........
Don't forget to use some M8 titanium nuts on the valve covers and engine case peripheral studs?
Kevin L
'86 Carrera "Larry"
Old 11-28-2018, 07:29 AM
DSPTurtle's Avatar
The amber tins save about 2.6 pounds, or 41.6 ounces, or 1,179.43 grams. The Ti bolts that someone emailed me a link to should be a nice touch.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 11-28-2018, 06:19 PM
Discseven's Avatar
...Although I have dropped $150 on less practical items
To your candor JB
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 12-04-2018, 09:19 AM
DSPTurtle's Avatar
My Ti fasteners finally showed up from who knows where. I had a chance to weigh them to get actual numbers. I used the normal steel washers for the comparison since they are under 1g each. They are about 1/3 the weight of the typical steel fastener. So about 1/3 of a pound when you combine all 39 of the M6x10mm pieces. Is the juice worth the squeeze, YMMV
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 12-21-2018, 07:35 AM
DSPTurtle's Avatar
I'm back... with more data.
I'm not sure who mentioned nylon fasteners but... thank you. They are .5g each. So I am going to run them in a few areas for a few weeks and see how they hold up. I have some concerns about the heat having a negative effect but they definitely are significantly lower weight. And as an added benefit, they won't rust! This pic is the equivalent number of fasteners while maintaining the same weight...
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 01-19-2019, 10:19 AM
Registered Minimalist
75 911s's Avatar
Hey how'd the nylon fasteners work out?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 01-25-2019, 05:49 AM
