Fanring Question
Hello everyone, does anyone know if it's okay to mount the fan ring 'upside down' or meaning the numbrers are located under/at the bottom. Mine is chipped where the numbers are and looks unsightly. Sorry for the stupid question....Thanks!
Old 03-29-2021, 01:25 AM
Racer
winders's Avatar
No, you can't. There is a short pin or peg on the engine that has a mating spot on the fan housing that locates it to the engine in the cradle. Also, there is a timing mark on the fan housing and it need to be on the bottom.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 03-29-2021, 01:55 AM
I'm surprised no one has made the joke about the OP being on the bottom side of the world, so upside down might end up being right way up!
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 03-29-2021, 02:12 AM
Racer
winders's Avatar
Upside down is right side up!
Scott Winders
PCA GT3 #3
Old 03-29-2021, 02:22 AM
Thanks Scott and Mike!
Old 03-29-2021, 02:43 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Mounting to hide the issue is not an option but they can be repaired.
Most are magnesium so a good welder can repair it. I have also seen some pretty cool repairs using a machinable epoxy.
Both of these repair will require some sort of paint to hide the issue but Cerakote can make the housing look pretty cool.
We do them in black and platinum.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-29-2021, 09:09 AM
Thanks for the tip Henry.
Old 03-31-2021, 05:42 AM
On this subject, is the original fan shroud coating paint or powder coat? If powder coat, is there a recommended method of removal?...
Old 03-31-2021, 08:16 AM
If by "fan shroud" you mean the fan ring: they are bare metal from the factory. No coating. If it is powder coated you can dip it in Berrymans carb dip (be careful not to leave it in too long) or neat the powder coating with a butane torch to break down the coating. At that point it should bead blast off pretty easily.
Henry Schmidt
Ph: 760-728-3062
Old 03-31-2021, 09:06 AM
Yep, Henry, I did mean fan ring. Thank you. Mine has been coated with something, but I guess not from the factory...
Old 03-31-2021, 09:45 AM
