Fanring Question
Hello everyone, does anyone know if it's okay to mount the fan ring 'upside down' or meaning the numbrers are located under/at the bottom. Mine is chipped where the numbers are and looks unsightly. Sorry for the stupid question....Thanks!
Racer
No, you can't. There is a short pin or peg on the engine that has a mating spot on the fan housing that locates it to the engine in the cradle. Also, there is a timing mark on the fan housing and it need to be on the bottom.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
I'm surprised no one has made the joke about the OP being on the bottom side of the world, so upside down might end up being right way up!
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Racer
Upside down is right side up!
Thanks Scott and Mike!
Try not, Do or Do not
Mounting to hide the issue is not an option but they can be repaired.
Most are magnesium so a good welder can repair it. I have also seen some pretty cool repairs using a machinable epoxy. Both of these repair will require some sort of paint to hide the issue but Cerakote can make the housing look pretty cool. We do them in black and platinum.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks for the tip Henry.
On this subject, is the original fan shroud coating paint or powder coat? If powder coat, is there a recommended method of removal?...
Yep, Henry, I did mean fan ring. Thank you. Mine has been coated with something, but I guess not from the factory...
