Piston Squirter Bore Size
I pulled the piston squirters from my case and found that the bores in the case measure 6.25-6.30mm. Is this normal?
I was expecting something closer to 6.0mm as I've read here that that is the stock size. The removed squirter bores are still in tact and they measure 6.25-6.30 suggesting a close press fit and there is some dryed sealant like loctite on them. I'm not sure if someone besides me has been into this engine before.
Is there a squirter availalble with a 6.25 outer diameter? I've read that oversize squirters are available at 6.6mm. I seem to be right inbetween the standard and oversize and not sure which way to go.
This is a 3.2 Carrera case from 1987.
Thanks.
Kevin
'87 Targa
Old 10-07-2019, 05:39 PM
"Catorce" on this board makes serviceable squirters. You will need to drill the hole oversize to install his 6.5 mm squirters. I've installed his, but not run the engine yet. Mine were original but also bigger than 6mm.
Old 10-07-2019, 08:13 PM
Thanks for the plug Ed!
Klax, here is your problem in a nutshell.
Porsche officially made TWO squirter sizes that you can buy from them.....6.0 and 6.6. No other part numbers are available.
YET, about 20% of the people that I sell squirters to have this intermediate size that measures around 6.25-6.3mm.
I have never received a satisfactory explanation as to why this is but I can tell you it is more common than you think. My best guess is that Porsche drilled a bunch of squirter holes wrong in the mid 1980s and then decided to fix them by ordering a custom bore to fill them.
The fix is pretty easy: You go to the overbore size of 6.6 which requires minor drilling. There really is no other way to avoid it.
Old 10-08-2019, 08:10 AM
Why couldn’t you just reuse the old ones that you took out?
Tony
Old 10-08-2019, 04:04 PM
Thanks guys. I’ll reach out to Catorce. I don’t think these are reusable items, I drilled away the top edge of the barrels to pull out the piston and internals and in the drilling process marked up most of the squirter holes. Also widened out the entry hole at the bottom with a screw.
Kevin
'87 Targa
Old 10-08-2019, 07:51 PM
Ah ok I get it. I’ve never replaced them, just blew them out.
Tony
Old 10-08-2019, 10:02 PM
Tony
No way to put them back in right after they are extracted due to really thin aluminum walls.
Old 10-09-2019, 09:01 AM
What is the price on this cleanable squirters and where to buy them?
Arild
Old 10-15-2019, 11:15 AM
Buy them on my site in the signature, $55 each same price as Porsche ones. thanks for your interest!
Old 10-15-2019, 12:52 PM
I love the idea of these and I have been trying to place an order for over two months but I get an error message when I go to the payment page.
Are these still available?
Old 02-21-2021, 08:42 AM
Senior Member
It says to call on the website.
Old 02-22-2021, 05:25 AM
It's a 914 ...
stownsen914's Avatar
Folks have been having a hard time getting in touch with the vendor for a few months now. Let us know if you have any success getting the squirters.
Old 02-22-2021, 05:32 AM
I am my 911's PO
'78 SC's Avatar
I ordered (and paid for) a set 9/5/2020 on the Taormina website.
Last response from Adam was 9/20/2020.
I'll update this when (if?) I get mine.
Old 02-22-2021, 08:27 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I have a set of the std. 6.0mm size for 911 oil pumps (not the larger 930 or larger pumps) if anybody is interested.
Rebuildable Oil Squirters- Std Size
Kevin L
'86 Carrera "Larry"
Old 02-23-2021, 08:13 AM
There’s also an email address directly below the phone number.
I emailed because that’s what people do in the twenty first century, especially when the person you are trying to contact is at the other side of the world.
I have had no reply, I suppose I shall have to wait for Adam to reappear.
Old 02-23-2021, 04:02 PM
Senior Member
And you still have no piston squirters.
Old 02-25-2021, 07:40 AM
Senior Member
From our host 911-101-011-01-Oem bought last month.
Old 02-25-2021, 07:50 AM
Senior Member
Add some retaining compound
Old 02-25-2021, 07:54 AM
I am my 911's PO
'78 SC's Avatar
From our host 911-101-011-01-Oem bought last month...[/img]
So, the new squirters are 6.25 mm, not 6.0 mm or 6.6 mm?
Did you measure the squirters you removed?
Old 02-26-2021, 05:47 AM
Senior Member
I’m just saying the ones I bought on two different occasions a few months ago all measured as shown above. I measured the bores not the actual squirter as the squirters become deformed when they are threaded for removal along with any residual retaining compound.
I think the reusable ones are NLA, I don’t think it was a profitable project as it was patented and I’m sure manufacturing wasn’t fast or cheap.
Old 02-26-2021, 06:17 AM
