canna change law physics
Ring Compressor
Does Pelican sell the ring compressor tool? I can't seem to find them in the catalog.
James
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
The tool manufacturer, Lisle, used to sell a take-apart type ring compressor with a plier-type ratcheting tool to compress and hold the band. They made it for Corvairs/VWs. Corvair pistons are about the same size as the Pcar. Check your local auto parts tool catalog.
Sherwood Lee http://members.rennlist.org/911pcars |
Senior Member
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Banned
I used a std hose clamp. The only shortfall is that you may have to use it two times to get the piston fully installed.
First clamp the first couple of rings, slide on the cylinder, past the first rings. Move the clamp if necessary to the final ring and slide on the cylinder. back off the clamp completely and unwind it around the piston. |
Snowman,
A hose clamp works as well. I would suggest using a hose clamp that has a solid band, not the type with the slots that go all the way through. The slots could nick the ring when tightening the clamp. Sherwood Lee |
Banned
Sherwood,
Thank you. Thats the only kind of clamps I use and I tend to forget about the junk stuff out there. |
Irrationally exuberant
Gee, now I feel embarrassed to admit I use a fancy Hazet ring compressor. I use to use the simple-band-that-you-squeeze-together-with-pliers types but my tool source (EBS) didn't have them for 98mm pistons (3.4L). The Hazet tool is pretty nice though...
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
don't be embarassed, the hazet is the cat's ass. hose clamps? come on now.
Author of "101 Projects"
Hose clamps? You've got to be kidding. That's almost as bad as the 2x4...
While I don't recommend spending $130 on a Hazet ring compressor, I do recommend the following: For assembling the pistons into the cylinders, you will need a ring compressor. With so much room for error in this process, I do not recommend purchasing a cheap ring compressor. Placing the pistons in your cylinders is a very delicate process, and if done incorrectly can easily lead to a broken ring, which will result in yet another teardown of the engine. There are $3 pieces of sheet steel for sale out there that are sold as ring compressors. I do not recommend using these, as it adds one more element of difficulty to the equation. A good quality ring compressor will cost about $20-$35 and will include a specially designed set of pliers whose specific purpose is to latch onto and compress the steel ring band. This type of compressor is much easier to use than the simple band one, and will reduce the chances that you will break a ring. Since the tool is relatively inexpensive when compared to the risks involved, I fully recommend that you purchase a good quality one. Compressing your rings is one of the most trickiest processes on the 911 engine. If you don't use the proper tool, you may end up with one of these: -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
That said, I was not happy with the ring compressor that I purchased for the new book. The sizes of the rings weren't quite fitting right. I'm looking for a better one for Pelican to carry...
-Wayne
I used a hose clamp. No problem. I would like to have one of those "cat's asses" though - they look cool.
993 |
No Expert
I have used Craftsman ratcheting ring compressor with very good results, but you can only use it if you are installing the pistons in the Jugs before you put the piston on the rod.
Hose clamp or Hazet, this is a tricky operation. I recommend practicing with an old piston, rings and jug, if at all possible. Even Wayne has broken a ring in this operation, but then again, he did not have a cat's ass.
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S |
Senior Member
By the time I was ready to go with my new Mahles, I had some confidence I could do the job without breaking anything. As far as the hose clamp thing goes....after spending a few thousands on a rebuild, what's the sense of *that*?
Snap-On Blue-Point RCL-30 2-1/8" to 5" range. Cost ~$19.00; easy to use on the bench plus unlatches to wrap around to compress rings in-situ. Jim
No Expert
Anyone ever try the Snap-on RCW60? It looks to have most of the features of the Hazet, but at $14. At that price, I have to try it.
http://buy.snapon.com/catalog/PRO.asp?tool=all&Group%5FID=1593&Group%5FName=Ring+Compressors&Sub%5FCat%5FID=1468745&Sub%5FCat%5FName=Ring+Compressors&Cat%5FID=1468743&Cat%5FNAME=Piston&store=snapon%2Dstore
Banned
I have access to all the ring compressors mentioned, and several more. I have tried all of them and the hose clamp works best of all, no kidding. The only down side is it will not catch all the rings at once. Maybe if I were not so cheep and bought two of them it would be easier.
I only use high quality solid stainless steel hose clamps. Do not attempt this with the ones with slots everywhere. |
...but make sure the 2x4 is properly positioned below your engine BEFORE using the hoseclamp!!!
993 |
stone knives, bearskins, hose clamps, 2x4s, hammers, axes, all the proper tools to do the job right.
Senior Member
I'm going to be adding the ring compressor tool very shortly...
-Wayne
