safe's Avatar
Originally Posted by msmall215 View Post
Magnus, what cams are you using?
From FVD.de, "sport" cam, they only have (or had) 2 grinds other than stock. You set it to 2.1mm. On my engine it makes top power under 6000 rpm and falls off at 6400, I think my exhaust is a bit restricting because it should make power higher up in the range. On a buddys engine they pull above 7000 and make 10hp more.
Magnus
Old 01-20-2020, 02:09 PM
The torque number is reasonable for flywheel, a bit high for rear wheel. Maybe that dyno is already corrected for drivetrain loss.
Sent from my Nokia 7.1 using Tapatalk
Old 01-22-2020, 04:41 PM
msmall215's Avatar
Thanks all for your insightful input. A quick update, my cylinders are with EBS for replating and honing. I've also decided to opt for a set of new CP pistons in 11:5:1 CR which will open up cam choice a bit. My goal is still to keep this motor rather mild to help elongate the life span of my 915 so cams will land somewhere in the DC24 range.
Mike
'85 3.2C
IG: @msmall90 | @zuffenphilly | @ruchlosrallye
Old 01-29-2020, 09:14 AM
11.5 ? thats a lot is it not ? How will you avoid detonation ?
80SC (ex California)
Old 01-31-2020, 08:25 AM
msmall215's Avatar
It's a 964 motor, will be running twin plug. Factory is 11:3:1 I believe.
Mike
'85 3.2C
Old 01-31-2020, 11:32 AM
Racer
winders's Avatar
Not really. It is more like 10.8:1 at most.....
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 01-31-2020, 12:44 PM
msmall215's Avatar
Fair enough, I was just going by published factory specs.
Mike
'85 3.2C
Old 01-31-2020, 12:47 PM
Racer
winders's Avatar
Maybe you missed the point. The point is that your 11.5:1 engine has a lot more compression than a standard 3.6 as delivered. So, if you are running pump gas, it would be good if your EFI system has knock sensors and can retard the timing.
Scott Winders
PCA GT3 #3
Old 01-31-2020, 01:04 PM
msmall215's Avatar
Ah gotcha. Yes plan is to run knock sensors to adjust on the fly. Will also be running 93 as available here in PA, and have a backup map for 91.
Mike
'85 3.2C
Old 01-31-2020, 01:09 PM
Racer
winders's Avatar
My race engine with about the same compression ratio and probably 25 degrees of advance needs 100 octane race gas to be safe. So be careful!
Scott Winders
PCA GT3 #3
Old 01-31-2020, 01:13 PM
I'm building this exact same setup and I'm hoping for 270 WHP. That would be a nice 90hp jump over my RoW 3.0 that dyno'd at 180 whp. I was recommended and went with 95 3.6 with Rasant ITB's/ GT3 Plenum DC 21 cams and AEM Stand Alone.
2024 GT4RS Ruby Star
2024 Raptor
2014 R8 V10
1982 911 3.6 Backdate
Old 02-04-2020, 06:11 AM
msmall215's Avatar
Solid package, Andrew does nice stuff. I have his AEM/harness setup in my ROW 3.0 right now with Triumph ITBs from Al Kosmal. I will also be going with the DC21.
Mike
'85 3.2C
Old 02-04-2020, 11:25 AM
