Try not, Do or Do not
Tired of crispy wires
I got so tired of messing with crispy, nasty old engine harnesses that we decided to make our own. Now we can offer them to all of you.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
82 911 SC - Ancora Imparo
Stupid question: how difficult is it to replace the engine wiring harness with the engine in the car? I'm going to drop mine but it'll be a while.
Ethan 1982 911 SC - Wine Red Metallic Coupe |
Replacing the engine harness in the car is doable but it's a huge pain. The later the car the more challenging the job.
ROW '78 911 Targa
Thanks. I’ll hold off until I have the engine out.
Great looking part. If we need an SC harness I'll definitely look at buying one of these.
ROW '78 911 Targa
Thanks Henry,
I’ll trade you 4 of them for one of your sweet looking 3.1 cylinder kits.
I see a sweet MFI harness from Henry and a sweet CIS harness from Timmy. Do either of you make a harness for a 3.0 CIS going to PMO carbs?
_______________________________ 1982 911 SC 240,000mi and counting |
I choose to use a double sender of pressure and idiot light that mounts on top of the engine to get a more accurate pressure reading. It also cleans up the wiring near the alternator housing. The temp wire runs under the fan rather than over the top. We can add the ignition/distributor wires but I prefer a stand alone harness for that. It allows for more ignition options. If you still have an external regulator we can add those wires as well.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 02-24-2020 at 03:42 PM.. |
ROW '78 911 Targa
I use FR Wrap. This picture is of one without the CDI wiring. Lots of different harnesses I’ve built posted over 32 pages here: Building SC and Mid Year Engine Harnesses
ROW '78 911 Targa
3.0 carb or EFI with ignition....
Just made one this weekend actually, in the mail tomorrow. The harness on the right is for a 3.0 carb engine with MSD with an adapter and extra wiring to make it plug and play with the MSD. The others in the photo are for brakes, fuel pump and front lighting harnesses for a stripped down hotrod.
