Walt, where did you get the oil cooler blockoff plate that's on the engine on the ground? I might buy one instead of wasting a whole day at the mill and lathe, fabricating a plate and fittings. Of course, that goes against most racer's mantra of "why should I spend money on that when I can waste a week at the mill and lathe making one??"
Old 06-30-2020, 06:47 AM
abit off center
cgarr's Avatar
The last head job I did was to rebuild the heads, clean the cam carriers and rebuild the rockers and assemble everything so it was ready to install. Actually came out really nice.
______________________
Craig
G2Performance
Old 06-30-2020, 10:11 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by cgarr View Post
... Actually came out really nice.
They sure did...
Who Will Live... Will See
Old 06-30-2020, 04:06 PM
Walt Fricke's Avatar
Dan - can you TIG? (I can't, so had it done). Take a leaking oil cooler (value$0), cut off the cooler part (no special tools needed), weld on a plate to take the in and out bungs far enough apart to use wrenches on the hose ends, and bolt in place.
I may have done this before the 993s arrived, and I didn't know the 964s had a filter housing (but its angle limited filter choices). What I did know about was Porsche's trick early racing filter with all those stacked disks (wonder how efficient those are, esp compared with more standard filters). The car was cooled by two Continental aircraft coolers in parallel up front (nowadays two 964 coolers after an accident dinged one of the acft ones and the local aircraft junk yard didn't have a replacement on the shelf), so the engine cooling was and is superfluous. Race cars don't sit idling and inching forward in traffic much.
All things being equal, now I'd buy, if starting out, the 993 system. Removing the filter from its housing is a separate step, even though only one or two nuts, and something extra to get in the way of pulling/installing the engine. Remoteness (by not much)doesn't seem to be a virtue in itself. Or, if I had a lathe and mill, fabricate something, tap the case maybe, consider welding bungs to the case.
But these have worked perfectly.
Old 06-30-2020, 09:10 PM
