Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
air injector plug size
Can someone give me the specs on the size plugs that go in the air injector holes on my 3.0 heads?
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 04-21-2003, 10:14 AM
Irrationally exuberant
ChrisBennet's Avatar
The plugs are M10x1. Link to thread on air injection plugs.
-Chris
Old 04-22-2003, 06:59 AM
Stahlwerks.com
jhelgesen's Avatar
So, do you think these plugs at www.mcmaster.com would work?
part number 92015A155
John Helgesen
Old 04-22-2003, 08:05 AM
the best ones are aftermarket 914 rear caliper plugs. hex head, and a flange. pelican should have them.
206 637 4071
Old 04-22-2003, 08:49 AM
No, those are the wrong pitch (1.5). The plugs need to be 1.0 pitch.
-Chris
Old 04-22-2003, 09:04 AM
Stahlwerks.com
jhelgesen's Avatar
Dooh, no fine thread plugs on there, I'll get them from Wayne,
Thanks Guys!
John Helgesen
Old 04-22-2003, 10:12 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
S caliper bleed valves are the same size. I had to order the tap to straighten out my front brakes from mcmaster.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 04-22-2003, 11:21 AM
Forced Induction Junkie
WERK I's Avatar
Chris,
Hey neighbor! Where is your "local metric hardware place"?
Enquiring minds want to know! :-)
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 04-23-2003, 08:30 AM
Author of "101 Projects"
Wayne 962's Avatar
I don't think that's true - I think that the bleed valves are the same size as the plugs in the earlier heads - the 2.7s? Althought I can't recall off the top of my head, and I don't have any cross-ref on this...
-Wayne
Old 04-24-2003, 01:48 AM
I know my 993 calipers and 930 caliper bleeders and Carrera brake lines are all 10x1.0 if that helps.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-24-2003, 04:08 AM
Tim Walsh's Avatar
I do know that 10x1 is the correct size for the bleeders. I don't know the correct size of the injection plugs though.
Tim
1973 911T
2005 VW GTI
Old 04-24-2003, 07:24 AM
I've plugged the ports in a 2.7 motor and an '81 SC motor with 10x1.0 plugs.
-Chris
Old 04-24-2003, 07:30 AM
beepbeep's Avatar
there are perfect plugs available for 1£ a pop from http://www.type-911.co.uk/
Pictures:
Stupid guide of fitting emmision plugs in three steps...
Thank you for your time,
Old 04-27-2003, 10:52 AM
