TRW Valves - Okay to use on a rebuild?
Valve Stem Oil Seal - which is the best to use?
Thanks in advance. |
PRO Motorsports
Viton will seal the best.
I prefer the Teflon because they let a little more lubricating oil down the guide and prolong the guide and stem life. (And TRW is the original supplier of the valves to Porsche.)
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
But I see a lot of people saying avoid the TRW valves. Should they be used?
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
abit off center
I used to have problems with them, the stems would be nicked up but the past year have not had a problem. Like any new part, look it over before use.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
