Reference sensor position on clutch - does it matter?
when putting the clutch on, does it matter where the reference sensor is? Should it be at TDC?
Marlin Ness
sadly no longer: 1967 912, 1971 911T, 1974 911 Targa, 1975 914, 1972 914 Eagle GT with V8
currently: 1972 914 Eagle GT with 3.2 Carrera, 1970 911T (964 turbo wide body look), 1986 911 Carrera
Old 11-25-2020, 04:55 PM
I actually meant the little set screw on the clutch with respect to the reference sensor itself?
Marlin Ness
Old 11-25-2020, 04:57 PM
safe's Avatar
Isn't that on the flywheel and not the clutch?
Magnus
Old 11-27-2020, 06:51 AM
of course. You are correct. Was a very late day. thanks. Maybe somebody will know the answer. Seems like it doesn't matter as I never tried adjusting anyways.
Marlin Ness
Old 11-27-2020, 08:06 AM
safe's Avatar
The flywheel is "keyed", It only fits in one position.
Magnus
Old 11-27-2020, 08:35 AM
thank you so much. best regards.
Marlin
Marlin Ness
Old 11-28-2020, 06:00 AM
Try not, Do or Do not
Henry Schmidt's Avatar
I see you found your answer but it's important to inspect the trigger pin for damage.
I have seen machine shops mangle the pin during resurfacing to the point of making the sensor clearance challenging if not impossible to adjust.
I've also seen replacement flywheels missing the pin altogether.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-28-2020, 07:37 AM
