-   -   rebuilding drbrian's 3.2l engine (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1079169-rebuilding-drbrians-3-2l-engine.html)
rcw911rsr 01-07-2021 12:28 PM
meanwhile, jose is lapping all of the ancillary parts that have flat surfaces to prevent any leaks.
http://forums.pelicanparts.com/uploa...1610051141.JPG
rcw911rsr 01-07-2021 01:37 PM
about to gap the rings. all of the cylinders mic out exactly 98mm.
http://forums.pelicanparts.com/uploa...1610055408.JPG
rcw911rsr 01-07-2021 04:52 PM
just finished gapping the rings. the ring grinder is turned off in the pics as obviously i do not want to ruin a ring trying to grind while taking a pic.
http://forums.pelicanparts.com/uploa...1610066997.JPG
rcw911rsr 01-07-2021 05:12 PM
to measure the gap i had to use two feeler gauges, a 0.40mm and a 0.04mm for a total of 0.44mm per mahle.
http://forums.pelicanparts.com/uploa...1610068294.JPG
rcw911rsr 01-07-2021 11:00 PM
carrillo suggests stretching their rod bolts over torqueing.
http://forums.pelicanparts.com/uploa...1610089214.JPG
rcw911rsr 01-07-2021 11:02 PM
so i just realized a vendor did not send the new timing chains. i have the crank ready to drop in. i hope my local dealer has them on the shelf...
mikedsilva 01-08-2021 05:05 PM
great thread. I'm envious of the tools you have!
What was the stretch spec of the bolts you used on the con rods and did you also get a corresponding torque value to compare with the spec sheet they supply?
rcw911rsr 01-08-2021 05:52 PM
the minimum tq spec was 40 which i ignore.
the stretch value for the rod bolts we used is 0.005 - 0.0065" per carrillo.
the actual tq value ended up being 55 ish ft lbs
rcw911rsr 01-08-2021 05:58 PM
so i had to drive to get the chains from a local supply house today. i just got done getting everything ready to carry on. i like to lay everything out and wash each part as i install them.
http://forums.pelicanparts.com/uploa...1610157391.JPG
rcw911rsr 01-09-2021 04:50 PM
i just realized my helper laid the blue orings out that are in the picture. i do not use the blue orings, but in fact go with the viton orings and dc molykote 55.
Cairo94507 01-11-2021 06:53 AM
Loving this build.
dkirk 01-11-2021 04:51 PM
Nice to see your great attention to detail. Thanks for this great post - really enjoying it.
ARCSinAK 01-11-2021 11:13 PM
Master class is in session!
rcw911rsr 01-12-2021 06:29 PM
sorry keeping this updated is as much or more time than blueprinting an engine! plus i am in the middle of 2 other restorations on a 964 c4 and 72 911 rsr extra widebody. :cool:
Originally Posted by Cairo94507 (Post 11176668)
Loving this build.
thx!
rcw911rsr 01-12-2021 06:30 PM
i can not say that the rest of the shop is as organized as the engine room, but somehow i know where everything is!
rcw911rsr 01-12-2021 06:31 PM
such a compliment! i simply try to build every car as if i am going to keep it till my last day.
rcw911rsr 01-12-2021 06:34 PM
so i am using the old original headsutds for my dry run to check clearances. i thought to do it both the old school way with modeling clay fully assembled and then take it down to the short block then pull the valve springs and show you the more accurate and faster way.
http://forums.pelicanparts.com/uploa...1610505269.JPG
rcw911rsr 01-12-2021 06:41 PM
once the short block is together i assemble each piston into it's respective cylinder. i find this is so much easier to do than trying to install the pistons in the cylinders on the eng, although when i do 996/997/991 i install them in the cylinders already on the engine.
be sure you put the top ring on top with the writing facing up, the second ring has a M and the oil ring is last. they are all 90* apart with the oil gap at the top.
http://forums.pelicanparts.com/uploa...1610505477.JPG
rcw911rsr 01-13-2021 11:17 AM
sorry i got a phone call last night then took off for the day.
