@reimaginedcoachwerks
here are a couple pic of the case work.
Old 01-04-2021, 07:49 PM
and a few of the crank work. the crank was std/std after 140k.
Old 01-04-2021, 07:51 PM
calling it a night. we got the case halves together and checked all of the case bores. i do not trust gauges, therefore i use not only the goto sunnen bore gauge with setting fixture; but i use my mitutoyo holtest inside micrometers. everything measured in spec.
we torqued the though case bolts.
if you are not familiar with how a bore gauge works, but at the rock over point is when you get the actual dimension therefore its hard to get the rock over point on camera. so the pics of the bore gauge are arbitrary.
the bore gauge is set with the setting fixture.
Old 01-04-2021, 10:57 PM
my favorite is to use a mitutoyo inside micrometer! i try to keep the room temp and humidity to the temp/hum that mitutoyo used when they calibrated these tools.
first i zero them.
Old 01-04-2021, 11:05 PM
then i measure each bore in 2 places each.
Old 01-04-2021, 11:06 PM
a few more...
Old 01-04-2021, 11:08 PM
PorscheGuy79's Avatar
The organization is extremely satisfying!
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 01-05-2021, 08:23 AM
superninety's Avatar
Nice work.
Who did you use for plating ? So few good platers in the DFW area. Who machined the heads?
TIA !
Robert Callaway
PCA | Early S Registry | R Gruppe
1970 T Coupe, 1990 C2 Coupe, 2007 Cayman S
1962 S90 Coupe - Gone, but never forgotten...
1985 Targa - A distant memory...
Old 01-05-2021, 08:37 AM
i get the heads done with a retired machinist that works by appointment only for long time clients. he also gets my hardware plated by one of his venders.
Old 01-05-2021, 11:46 AM
i was trained by the legend John Bray, owner of evospec in AZ, many moons ago and he sets a high standard at his shop. you have to spend one solid day minimum cleaning all of the parts one by one, over and over and over...
Old 01-05-2021, 11:49 AM
a few pics of old versus new parts for dr. brian.
Old 01-05-2021, 11:51 AM
here we measure the crank with outside micrometers. first we zero the micrometer then start with the main journals.
ADD 50MM TO EACH MEASURMENT
Old 01-05-2021, 12:55 PM
here are the rod journals.
ADD 50 MM TO EACH MEASUREMENT
Old 01-05-2021, 01:02 PM
ADD 25MM TO EACH MEASUREMENT
Old 01-05-2021, 01:06 PM
ADD 75MM TO EACH MEASUREMENT
Old 01-05-2021, 01:08 PM
Good to know.
Robert Callaway
Old 01-05-2021, 01:11 PM
Subscribed! Dr. Brian, your 911 is bad ass! Great work rcw911rsr! I'm looking forward to this build.
Old 01-05-2021, 03:01 PM
remeasuring with mechanical mics to double check.
Old 01-05-2021, 03:12 PM
rod journals
Old 01-05-2021, 03:14 PM
Old 01-05-2021, 03:16 PM
