Puny Bird
Correct but IIRC the MSD 6TN/6ALN NASCAR CD Ignitions 6430 is basically a 6AL, just 2.5-3X the money.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Try not, Do or Do not
The exception was a clear base plate so the box could be visually inspected. MSD claims 'Extreme duty" whatever that means.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 03-05-2021 at 10:26 AM.. |
I think the internal potting was also clear, so that the electronics could be inspected and/or offer protection from tampering. Previously the potting was black and could not be easily inspected for the aforementioned traction control by the tech officials. The potting "also" offered "vibration protection."
This sounds interesting. Do you know if it's possible to use the input for the rev limiter chip to create a similar effect (IE: traction control)?
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
The outlaw traction control was done through the circuitry designed for the rev limiter chip, inside the box, so as not to be easily detected. Davis Technologies has a box that plugs in place of the rev limiter chip, but I think MSD must have learned a lot from the confiscated boxes too, because I see that they now sell traction control on the Holley website. I have no idea what other devices it takes to make theirs work though.
https://moretraction.com/ Davis's prices are crazy high for traction control though. If you're not racing with it, you could get similar traction control for a lot less. Even some of the aftermarket EFI ECU's come with it now. |
I had the add-on traction control on my racebike that was programable for sensitivity. Not sure if that actually answers the question, but once the genie was out of the bottle, they had to lift the ban. TC now is unbelievably complex in MotoGP, even with the standard ECU. Throttle and ignition mapping is custom tailored per gear and per corner and based on lean angle. GPS was outlawed, but with the start/finish timing loop, the bike does know where it is on track. |
New prototype Duel CD coming soon. Designed and manufactured in the USA.
Testing is on going and limited manufacturing is happening.... Now! One CD triggering two coils. The box is small (5"x6"x2") and designed to be Porsche specific. All wiring color coding is familiar to anyone who works on the air-cooled engines. ![]() ![]() ![]()
May I throw my hat in the ring now too.
Great more are becoming available for the market to choose from. What I am pleased about is this new one is also CDI. I have been selling CDI Ignition for years from these large hemi chamber engines and found in our own testing, that these engines start easier, run better and make more torque with CDI. We have tested about every other Inductive system available and found nothing that comes close. Maybe others have found the opposite result, as I see many engines running Inductive Ignition. I often think its all about simplicity and cost. The engine runs and make power so why the need for CDI? Its in our name, Performance Developments! We have been selling this system for years that drives two coils simultaneously. This is well proven, we have been selling this product and the other options for over 25+ years without any failures. Check out M&W Pro 14 dual coil for Porsche. We make up a simple small adapter harness that plugs right into the stock harness. Single channel system for both Points or reluctor triggered engine are also available. Keep them coming as more is always better. |
We mate the CDI with its own made for CDI Coils.
M&W has been producing great products for many years, great choice.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
What could be better?
More options to enhance my twin plug distributors. ![]()
Nice and neat looking. And there is a real call for two channel CDI systems. Looks like something Bob Ashlock might have done. I'm not going to build a two channel unit. If someone wants to fire two coils they will need two boxes. I'm even going to go more retrograde on a handful of units by using some NOS 1963 germanium power transistors that have aged well. But those units won't be going on race cars. Fred
You are correct. Bob is the genius behind this clean little system.
I designed the housing and wiring components to incorporate his electronics into an easy to use, cost effective, high energy system. Even the wiring codes will be Porsche compatible. I spoke with M&W ignitions (highly recommended) but elected to work with a small, home grown company nearer to my location. I like the thought of working with local technicians with the drive and willingness to nibble around the edges.
Believe me when I say it was an educated guess that this was Ashlock's work. The simplicity and layout of the board, for the work it has to do was the clue. You've partnered with a good man. Fred
Rosco_NZ
![]() ![]() For anyone interested, I did end up installing twin CDI boxes into my build .. rubber mounted Daytona Sensors CD-1. |
Rosco_NZ
But I have yet to install a Twin Plug distributor. If anyone knows of spare JB Racing distributor, love to hear from you.
Why not get one from Henry?
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
Here is our new twin CD. Small size [5"X6"], long harness for mounting diversity, state of the art electronics. Custom adjustable rev limiter.
Our distributors are custom built per/application in Bosch or Marelli options. ![]()
| Tags |
| 2.7rs , cdi , twin spark |
