Try not, Do or Do not
Does anyone have an answer to this:
NASCAR uses a power supply that boosts 12v to 18v for their MSD. Do you have any thoughts about what that does to energy delivery?
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
It would lead to all sorts of problems on our cars. I know of a race car that runs a 600V ignition. Eats a plug set in two outings.
www.classicretrofit.com |
If higher energy eats spark plugs does it also eat rotors and dist. caps?
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 02-28-2021 at 09:56 AM.. |
drama time anyone ? If you like reverse my #1 and #2 I think I have the order correct.
Racer
Of course, since you are a "cool kid" and an idiot, I must be an idiot for choosing you to build my engine. It must be just blind luck that have an engine that works at all.....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
In the FAQ section of MSDs website it talks about running different input voltage into the MSD CDI and states that between 10v and 16v the output will be the same because the output is regulated.
That's the digital box. The analog MSD is not regulated.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
This is a perfect example of what happens when confirmation bias meets desperation.
On that topic, here's a video I made some time ago showing how a Bosch CDI coil voltage varies with battery voltage and also RPM: https://youtu.be/K65slwl__dk
^ yeah, not sure what I've stepped into here. Just trying to offer an EE perspective. Gonna duck out for a bit.
Puny Bird
Moving right along...what is the best oil for my Porsche?
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
^^^^^^^ lol.
Canola?On another note Mark, please send me an email so we can discuss the services you offer as we are always looking to make new connections.... Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Jonny, You need to buy an old MSD 6A and test it (no longer made from what I hear). The rated voltage occurs at 18V on the two I own from 20 years apart. They give a battery voltage range and then made the claim of voltage when in fact it was for 18V, not a typical 14V. The old MSD 6A is actually quite gutless when a single spark in the series is considered. I can't speak for their other products as I have not tested those. It doesn't get anywhere near 800V at 18V applied! Fred
Nascar Cup cars quit using MSD boxes when the R07 engine came out (2011?) At least that was when it was in testing.
The biggest problem with MSD boxes in the pro categories was that some (most?) teams were adding traction control internally and nascar couldn't police it effectively. Mclaren/Freescale ECU's are effectively anti tamper proof, where any modifications are traceable and detectable at the track. The MSD boxes were routinely sent back to MSD to look for any modifications. That took days. The way that the traction control worked was in conjunction with the rev limiting software. If the engine rpm climbed above a certain rate, the ignition timing was retarded. There were no wheel speed/driveshaft speed, car speed sensors needed, only the engine speed input. And obviously the ignition box needed to see that. We all pointed fingers at each other and it all seemed to get swept under the rug with nobody ever getting "busted" for it. Until EFI and the Mclaren ECU's came out and leveled the playing field. |
Dan - great NASCAR story!
In my case, with an LSD and relatively low HP, wheel spin isn't an issue unless the track is wet or dirty. Certainly not in a straight line on dry track. Is it wheel spin the fiddling was aimed at preventing? |
Yup, wheel spin. Think about it, if you could come out of a corner, any corner, every corner, and just floor it every single time, without the risk of getting sideways, you'd look like the best driver since Steve McQueen. And the traction control was so good and so fast that it seemed seamless. Lap after lap after lap. And quite honestly, some of the most veteran drivers of all time were seething that some rookie kid could outdrive them after just a few laps on a track they've never seen before, other than on a video simulator.
| Tags |
| 2.7rs , cdi , twin spark |
