2.5 L piston question
Can a 2.4 L mag case accept an 86.7mm piston without enlarging the spigots? Thanks
Euro Spec 73 911S 72T, now ST R Gruppe, S Registry |
If you are referring to the Mahle 86.7 pistons and cylinders then you either need to enlarge the spigots or turn down the cylinders. I used those P&Cs in one of my 2.5s and I elected to turn down the cylinders to fit the 2.4 spigots.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Yes, the Mahle 86.7’s. Thanks.
Try not, Do or Do not
+1
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Henry... Great to see you back in action. I should have said, Henry built me a 2.5 with the 86.7mm Mahles and we elected to turn down the cylinders. 🙂
Makes a great engine. Cheers
Can’t get a better endorsement than that! Thanks Henry. I have a feeling it’s going to be a challenge to acquire the parts I need: heads, pistons and cylinders. Any leads or ideas are appreciated.
Call us. We have thousands a early 911 engine parts to build any of the conventional or innovative engine configurations that 50 years of developed has innodated the enthusiasts imagination.
You owe me a visit. Give me a minute and we'll find a day to connect, Your 915 is ready if you want to pick it up.
Thanks Henry. I just asked Glenn Roberts to give you a call. He know what we are up to.
