NickP's Avatar
2.5 L piston question
Can a 2.4 L mag case accept an 86.7mm piston without enlarging the spigots? Thanks
Euro Spec 73 911S
72T, now ST
R Gruppe, S Registry
Old 01-20-2022, 05:53 PM
If you are referring to the Mahle 86.7 pistons and cylinders then you either need to enlarge the spigots or turn down the cylinders. I used those P&Cs in one of my 2.5s and I elected to turn down the cylinders to fit the 2.4 spigots.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 01-20-2022, 06:16 PM
NickP's Avatar
Yes, the Mahle 86.7’s. Thanks.
Euro Spec 73 911S
72T, now ST
Old 01-20-2022, 07:12 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by jbell959 View Post
if you are referring to the mahle 86.7 pistons and cylinders then you either need to enlarge the spigots or turn down the cylinders. I used those p&cs in one of my 2.5s and i elected to turn down the cylinders to fit the 2.4 spigots.
+1
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-21-2022, 10:45 AM
Originally Posted by Henry Schmidt View Post
+1
Henry... Great to see you back in action. I should have said, Henry built me a 2.5 with the 86.7mm Mahles and we elected to turn down the cylinders. 🙂
Makes a great engine. Cheers
Old 01-21-2022, 10:51 AM
NickP's Avatar
Can’t get a better endorsement than that! Thanks Henry. I have a feeling it’s going to be a challenge to acquire the parts I need: heads, pistons and cylinders. Any leads or ideas are appreciated.
Euro Spec 73 911S
72T, now ST
Old 01-21-2022, 12:45 PM
Call us. We have thousands a early 911 engine parts to build any of the conventional or innovative engine configurations that 50 years of developed has innodated the enthusiasts imagination.
Henry Schmidt
Ph: 760-728-3062
Old 01-21-2022, 01:09 PM
Henry... Great to see you back in action. I should have said, Henry built me a 2.5 with the 86.7mm Mahles and we elected to turn down the cylinders. ��
Thanks John
You owe me a visit. Give me a minute and we'll find a day to connect, Your 915 is ready if you want to pick it up.
Henry Schmidt
Ph: 760-728-3062
Old 01-21-2022, 01:32 PM
NickP's Avatar
Thanks Henry. I just asked Glenn Roberts to give you a call. He know what we are up to.
Euro Spec 73 911S
72T, now ST
Old 01-21-2022, 01:55 PM
