twin plug triggering devise
Wanting to use a 3.6 twin dist in a earlier 3.0 engine build, What do you guys use as a trigging devise for the ignition system. Does anyone sell a Hall effect unit that can be mounted in the dist. ? Looking for something simple yet dependable. That maybe able to use 993 style module and coils. Thanks
Old 06-24-2021, 09:40 AM
I would rather be driving
jpnovak's Avatar
I use a hall effect sensor on the case and magnets in the stock pulley.
You are on your own about mounting a hall effect inside the distributor.
I have converted a 3.0 to Crane optical trigger before to run in an early car. Wasn't too difficult. Could probably do the same on a 3.6. The challenge is that the timing belt takes up a lot of space where you would mount the pass-through window wheel and sensor.
Old 06-24-2021, 01:33 PM
JB Racing has 12 point distributors with internal triggering for the 3.0. opposite rotation direction so hard to use the 3.6 distr.
80SC (ex California)
Old 06-24-2021, 10:25 PM
Puny Bird
Mark Henry's Avatar
Yes on my 3.0 I had to swap the dizzy drive gear to use the PMS TP dizzy I picked up, you can only do this with the crank out of the case.
Cheapest method to trigger twin plug is scrapyard Ford EDIS parts, a crank trigger and Mega Jolt JR.
You can also do Mega Squirt crank trigger for "ignition only", and have future FI.
Used Clewett systems come up for sale, made by Tec, GM coils.
Both Clewett and SDS EFI offer ignition only new systems.
Then you're into twin plug dizzys.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 06-25-2021, 11:08 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Supertec has a few different options. 27mm and 30mm shaft, CCW and CW and Bosch or Marelli. A plethora of distributors on the shelf.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-04-2021, 08:39 AM
