Crush washers
I thought it would be nice to have a supply of aluminum washers. So, I ordered washers for 6 & 8 mm. I got bags with labels saying Wurth, pull from stock. I hope they didn’t have some poor employee count out 100 washers for each bag. Although one bag had a 6 mm label and the other an 8 mm label, the washers were all identical. In use the washers are so soft that the alloy flows into the threads between nut and stud. I can see how this would help to prevent oil leaks, but it also prevents disassembly. I had to replace a couple of studs because the alloy glued itself to the threads and tore the ridges off when I tried to back off the nut. Bruce Anderson comments about this in his book on engine building.
Question though is how to get better quality stuff. I am hoping to avoid the thousand percent markup because the box has the Porsche crest on it. However, if they do quality control maybe it is worth it.
Thanks folks. I figure I still have a couple months before snow fall in which to drive. Either the TR6 or the 914 3.2 Carrera…
Old 07-13-2021, 05:46 PM
Yes , the Wurth aluminum washers are not good for nuts that are tightened above 8 ft / lbs . SSF sells good ones ,and so does Metric & Multistandard Components Corp . [metricmcc.com ].
Old 07-13-2021, 08:47 PM
Jeff Alton's Avatar
Never had an issue with Wurth hardware. Mind you, they don't manufacture it, but not had any issues.
www.turn3autosport.com
Old 07-13-2021, 09:11 PM
JoeMag's Avatar
Bell Metric is also a good source... Prices are great, though I'm not really fond of their shipping cost which is around $10 no matter how small the order is. My guess is you're really paying for someone to pack them up as they come in individually labeled small zip bags.
If you're into the yellow zinc for steel bolts, they're the place.
Old 07-14-2021, 10:04 AM
Try not, Do or Do not
Henry Schmidt's Avatar
There is absolutely different qualities of aluminum, cooper and steel washers. We use AN hardware whenever possible (Coast Fab) but for cooper and aluminum we only use the hardware sold by Charlie @ Wrightwood Racing.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-14-2021, 02:37 PM
It's a 914 ...
stownsen914's Avatar
I think it was Bruce Anderson who mentioned that dead soft aluminum washers are not the ones you want for valve covers.
As for the 6mm vs. 8mm washers being the same, sounds like someone mislabeled the package.
Old 07-19-2021, 08:01 AM
They usually don't count them, they usually weigh them. Scoop them onto a scale, pour more in or take some out until they weigh the right amount ( usually to a tenth of an ounce or so ).
I need sealing washers for the oil level sender, myself.
Old 07-22-2021, 08:33 AM
Registered User 4'10
Aluminum washers wanted
Yeah, I could use a few of the 'correct' aluminum crush washers also. If anyone has any extras, PM me, and I'll snail-mail you a stamp to snail-mail them back to me. $$ S/H charges for a couple of little BS parts, really 'aggravates' me! jt
jt - '69 911E, PCA-RMR '75-'82; Current Other: '16 BMW 328i, '18 Subaru Forester, '09 Kawi Concours 14, '85 VW Westfalia, C172, C152; Previous Notables: '89 Goldwing (RIP), '80 Suzuki 850, '64 Ducati 250, '64 Bug (wish I'd known about that #3 exhaust valve...), '59 Austin-Healey BN100-6, '59 Impala 2-door hard-top (cool!). '49 Cushman motor scooter, Grumman AA5A & AA5B
Old 08-14-2021, 04:16 PM
