Wiring for a 3.2 project
So I have a 1971 VW camper van that has been completely rebuilt and built around a 3.2 1985 carrera engine which has been rebuilt alongside a 915 transmission.
This has been fitted with PMO carbs as I want something that will be more like a vintage engine.
So an earlier post on here helped me figure out that ignition will work with a 2.7 distributor (with 3.2 drive gear) and a 3 pin CDI unit.
The bit I don't know and can't figure out is the rest of the wiring. What cables need to go to the CDI unit? is it simply a positive from the ignition switch?
Also, I have the original alternator and loom but unsure how to wire this up.
Looked at a few 85 wiring diagrams but none clear enough to work out how to backdate this to distributor and CDI unit wiring instead of the original 85 ECU setup. Anyone?
Old 09-11-2021, 01:04 PM
Originally Posted by HarryD View Post
This is the Pin out for the 3 pin connector:
Check out this thread.
76 911 CDI wiring???
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 09-11-2021, 05:26 PM
Originally Posted by snbush67 View Post
Link doesn't work?
Old 09-13-2021, 08:38 AM
Old 09-13-2021, 05:30 PM
