Wiring for a 3.2 project
So I have a 1971 VW camper van that has been completely rebuilt and built around a 3.2 1985 carrera engine which has been rebuilt alongside a 915 transmission.
This has been fitted with PMO carbs as I want something that will be more like a vintage engine. So an earlier post on here helped me figure out that ignition will work with a 2.7 distributor (with 3.2 drive gear) and a 3 pin CDI unit. The bit I don't know and can't figure out is the rest of the wiring. What cables need to go to the CDI unit? is it simply a positive from the ignition switch? Also, I have the original alternator and loom but unsure how to wire this up. Looked at a few 85 wiring diagrams but none clear enough to work out how to backdate this to distributor and CDI unit wiring instead of the original 85 ECU setup. Anyone? |
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 09-13-2021 at 05:30 PM.. Reason: Wrong link posted |
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
