Where to apply sealant
Officially in the reassembly mode of my 2.4 rebuild. I did not split the case. Have the reseal kit with all the gaskets etc. Are there areas where I should use sealant? Additionally, are there areas where I should use Locktite? I am using all new hardware (nuts, bolts washers etc.).
Thanks Chris 73 911 E |
Base gaskets: Curil T or aviation gasket maker
Cam towers to heads: Locktite 574 Cam carrier, chain box, chain box cover: Locktite 574 Intake manifolds: Curil T Bolts for fan shroud: Red Locktite Flywheel bolts: Red Locktite |
Isn't red locktite a bit much for the fan shroud?
Ed 1973.5 T |
up-fixing der car(ma)
I have done this a few times. This is my method (no issues):
-No Silicone RTV anywhere- let's just get it out there - None! Case perimeter- Threebond 1104/1194 Case main saddles - Loctite 574 #8 Bearing - Threebond 1211 Flywheel seal - Curil T Base gaskets- Curil T Cam tower to Heads - Threebond 1104/1194 Chain box to case and chain box to chain box covers - Loctite 518 Anywhere you are using a paper gasket besides valve covers - Loctite 518 Red Loctite on Head Studs - CASE side (and nowhere else) The next guy that takes the flywheel off the motor where you put red loctite is going to want to F-in' kill you (and that may be you, trying to kill yourself in the past). Or if you put it on the exhaust studs that go into the heads. Don't do it! This is tried and true. It works well to keep the engine from leaking, and it comes apart with minimal fuss. Loctite 574 hardens and requires a razor to remove; it makes gaskets hard and brittle (and stick). Loctite 518 stays supple and fills large gaps when mating with gaskets.
Scott Kinder kindersport @ gmail.com |
I use 574 on the bottom of the paper gaskets on the chain boxes and bottom of the covers.
Never, repeat never use red locktite.... Bruce |
Wow, glad I asked.
So I am clear, Loctite Red is for the threads. The other loctites are a type of form a gasket and supplement the paper gaskets. Are the base gaskets you are refering to the brass gaskets at the bottom of the cylinders? You are telling me to use the Curil T on the bottom of the brass gaskets(between the gasket and the case). I did not split the case and am leaving all that alone
Why not use 518 on the lower valve covers. I seem to always get some leakage there. Does it leave a mess when doing valve adjustments later?
Chris 73 911 E |
I've had few problems with Locktite red on the bolts mentioned above. I think the end use of the motor has a lot to do with your choices though. If you are building a motor that needs frequent dis-assembly, the blue is a better choice as is something other than 574. But if you're building a motor that will stay in the car for the next ten years, I stand by my advice.
There is a thread here called "Ultimate Sealants" that gets to the skinny of it all. Since you said you weren't splitting the case, I stuck with the required procedures for a cylinders up rebuild. There will be infinite opinions here so look around. |
Red Loctite is valuable for keeping the flywheel bolts where they belong in the 6 bolt 70.4mm cranks. An impact gun has no problems removing these bolts. They come right out as required.
However, if you are not going to spin the motor up to 8,000 rpm (or above), it is not necessary, and so shouldn't be done. Walt |
Super Moderator
Mechanics and future owners everywhere thank you sir. I think labor rates should go up based on every ounce of silicone used by the prior owner.
+1 with what Chris and Scott said!!
I am currently working on a 1978 3.0L and am finding RTV everywhere. What a mess...with little pieces floating around inside the case too. Wonder how the oil was flowing, huh?
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
Hi to all:
I am in the process of my rebuild and can't find either the TB 1211 or the Curil T. What can be used instead for the cylinder base gaskets and the No. 8 bearing? Thanks as always, Francisco Soto |
You can get both from Henry Schmidt at Supertec. I used Curil T on my nose bearing O-ring and it leaks. I used aviation gasket maker on the base gaskets and they do not.
Lindy |
I use orange Loctite around the outermost part of the nose bearing (outboard of the O ring). No leaks, but then again maybe it wouldn't anyway.
I have never used anything on the base gaskets, and have never had a leak. Or at least not enough so there is a drip. Sometimes a little more dust/grime may gather in that area. So there are lots of ways which can work (just as there are quite a number of sealants which will work). And some which don't. |
Lindy:
Thanks for your quick reply. But I live in Puerto Rico and I think these sealants can't be send by air (because of flammability, I think). I was thinking about using Permatex 518 Anaerobic gasket maker (which I already have) for the nose bearing (between the o'ring and exterior part) and maybe TB 1194 in the cylinder base gaskets. What do you think? Thanks, Francisco |
Try not, Do or Do not
John was kind enough to post this picture a few years ago and it's how we've been sealing engines for years.
![]() Outer case halves perimeter : Threebond 1104 or 1194 Bearing web surfaces: Loctite 574 #8 Bearing O-Ring: Threebond 1211 Case Thru Bolts: Dow Corning 55 on Green Viton O-Rings Flywheel Seal: dry Front pulley Seal: dry Intermediate Shaft Cover to Case: o-ring Dow 55, gasket style 574 Oil Breather Cover to Case: Loctite 574 Cylinders to Case: Curil T Cam Towers to Cylinder Heads: Threebond 1104 Cam Chain Housings to Case: gaskets Loctite 574 Cam Chain Housings to Cam Towers: gasket Loctite 574 Cam Chain Housing Cover to Cam Chain Housing: Gasket Loctite574 Gaskets: Thin coat of Loctite 574
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks Henry, I saw that picture before, but would like to know what other brand can substitute the TB1211 on the no. 8 bearing? Maybe Permatex 518 Anaerobic gasket maker?
Thanks, Francisco |
We tried using a slightly larger o-ring but finally succumbed to the need for a consistent technique. To answer your question: there are probably many sealants that will work for this application but to date ThreeBond 1211 is the best we've found. Good luck if you choose to experiment. Let us know how that goes. We are always looking for improved methods for assembling these old engine. Cheers
Why would it be necessary to put any sealant on the bearing saddles?
These is no leakage path and the sealant should not stabilize the saddles. I have been told it should not be done.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
The choice is yours. One additional thought: Shuffle is a real issue in a high performance Porsche engine that can be best addressed by methods like shuffle pins or hollow dowels. That said, anything that can add to the stability of the engine platform is a good thing and we have first hand experience that gluing the webs reduces shuffle.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 10-15-2010 at 05:16 PM.. |
| Tags |
| case sealants |
