cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Where to apply sealant
Officially in the reassembly mode of my 2.4 rebuild. I did not split the case. Have the reseal kit with all the gaskets etc. Are there areas where I should use sealant? Additionally, are there areas where I should use Locktite? I am using all new hardware (nuts, bolts washers etc.).
Chris
73 911 E
Old 10-05-2010, 02:07 PM
Base gaskets: Curil T or aviation gasket maker
Cam towers to heads: Locktite 574
Cam carrier, chain box, chain box cover: Locktite 574
Intake manifolds: Curil T
Bolts for fan shroud: Red Locktite
Flywheel bolts: Red Locktite
Old 10-05-2010, 03:01 PM
E Sully's Avatar
Isn't red locktite a bit much for the fan shroud?
Ed
1973.5 T
Old 10-05-2010, 04:11 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
I have done this a few times. This is my method (no issues):
-No Silicone RTV anywhere- let's just get it out there - None!
Case perimeter- Threebond 1104/1194
Case main saddles - Loctite 574
#8 Bearing - Threebond 1211
Flywheel seal - Curil T
Base gaskets- Curil T
Cam tower to Heads - Threebond 1104/1194
Chain box to case and chain box to chain box covers - Loctite 518
Anywhere you are using a paper gasket besides valve covers - Loctite 518
Red Loctite on Head Studs - CASE side (and nowhere else) The next guy that takes the flywheel off the motor where you put red loctite is going to want to F-in' kill you (and that may be you, trying to kill yourself in the past). Or if you put it on the exhaust studs that go into the heads. Don't do it!
This is tried and true. It works well to keep the engine from leaking, and it comes apart with minimal fuss. Loctite 574 hardens and requires a razor to remove; it makes gaskets hard and brittle (and stick). Loctite 518 stays supple and fills large gaps when mating with gaskets.
Scott Kinder
kindersport @ gmail.com
Old 10-05-2010, 05:06 PM
I use 574 on the bottom of the paper gaskets on the chain boxes and bottom of the covers.
Never, repeat never use red locktite....
Bruce
Old 10-05-2010, 05:54 PM
cmcfaul's Avatar
Wow, glad I asked.
So I am clear, Loctite Red is for the threads. The other loctites are a type of form a gasket and supplement the paper gaskets.
Are the base gaskets you are refering to the brass gaskets at the bottom of the cylinders? You are telling me to use the Curil T on the bottom of the brass gaskets(between the gasket and the case). I did not split the case and am leaving all that alone
Old 10-05-2010, 08:04 PM
cmcfaul's Avatar
Why not use 518 on the lower valve covers. I seem to always get some leakage there. Does it leave a mess when doing valve adjustments later?
Chris
73 911 E
Old 10-05-2010, 08:32 PM
I've had few problems with Locktite red on the bolts mentioned above. I think the end use of the motor has a lot to do with your choices though. If you are building a motor that needs frequent dis-assembly, the blue is a better choice as is something other than 574. But if you're building a motor that will stay in the car for the next ten years, I stand by my advice.
There is a thread here called "Ultimate Sealants" that gets to the skinny of it all. Since you said you weren't splitting the case, I stuck with the required procedures for a cylinders up rebuild. There will be infinite opinions here so look around.
Old 10-06-2010, 07:05 AM
Walt Fricke's Avatar
Red Loctite is valuable for keeping the flywheel bolts where they belong in the 6 bolt 70.4mm cranks. An impact gun has no problems removing these bolts. They come right out as required.
However, if you are not going to spin the motor up to 8,000 rpm (or above), it is not necessary, and so shouldn't be done.
Walt
Old 10-10-2010, 08:35 AM
Super Moderator
cstreit's Avatar
Mechanics and future owners everywhere thank you sir. I think labor rates should go up based on every ounce of silicone used by the prior owner.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-12-2010, 02:19 PM
TibetanT's Avatar
+1 with what Chris and Scott said!!
I am currently working on a 1978 3.0L and am finding RTV everywhere. What a mess...with little pieces floating around inside the case too. Wonder how the oil was flowing, huh?
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 10-12-2010, 10:50 PM
Hi to all:
I am in the process of my rebuild and can't find either the TB 1211 or the Curil T. What can be used instead for the cylinder base gaskets and the No. 8 bearing?
Thanks as always,
Francisco Soto
Old 10-13-2010, 06:12 AM
You can get both from Henry Schmidt at Supertec. I used Curil T on my nose bearing O-ring and it leaks. I used aviation gasket maker on the base gaskets and they do not.
Lindy
Old 10-13-2010, 06:44 AM
I use orange Loctite around the outermost part of the nose bearing (outboard of the O ring). No leaks, but then again maybe it wouldn't anyway.
I have never used anything on the base gaskets, and have never had a leak. Or at least not enough so there is a drip. Sometimes a little more dust/grime may gather in that area.
So there are lots of ways which can work (just as there are quite a number of sealants which will work).
And some which don't.
Old 10-13-2010, 07:30 AM
Lindy:
Thanks for your quick reply. But I live in Puerto Rico and I think these sealants can't be send by air (because of flammability, I think). I was thinking about using Permatex 518 Anaerobic gasket maker (which I already have) for the nose bearing (between the o'ring and exterior part) and maybe TB 1194 in the cylinder base gaskets.
What do you think?
Thanks,
Francisco
Old 10-13-2010, 07:32 AM
Try not, Do or Do not
Henry Schmidt's Avatar
John was kind enough to post this picture a few years ago and it's how we've been sealing engines for years.
Outer case halves perimeter : Threebond 1104 or 1194
Bearing web surfaces: Loctite 574
#8 Bearing O-Ring: Threebond 1211
Case Thru Bolts: Dow Corning 55 on Green Viton O-Rings
Flywheel Seal: dry
Front pulley Seal: dry
Intermediate Shaft Cover to Case: o-ring Dow 55, gasket style 574
Oil Breather Cover to Case: Loctite 574
Cylinders to Case: Curil T
Cam Towers to Cylinder Heads: Threebond 1104
Cam Chain Housings to Case: gaskets Loctite 574
Cam Chain Housings to Cam Towers: gasket Loctite 574
Cam Chain Housing Cover to Cam Chain Housing: Gasket Loctite574
Gaskets: Thin coat of Loctite 574
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-13-2010, 08:36 AM
Thanks Henry, I saw that picture before, but would like to know what other brand can substitute the TB1211 on the no. 8 bearing? Maybe Permatex 518 Anaerobic gasket maker?
Thanks,
Francisco
Old 10-15-2010, 04:42 AM
Thanks,
Francisco
Over the years we resisted putting any glue on the #8 main bearing but after measuring the case bore we consistently found that it was not round. Sometimes as much as .015 out of round. Boring the case is an option but most of the shops that do align bore only bore this bearing location if they are shaving the case and bringing the case back to standard.
We tried using a slightly larger o-ring but finally succumbed to the need for a consistent technique.
To answer your question: there are probably many sealants that will work for this application but to date ThreeBond 1211 is the best we've found.
Good luck if you choose to experiment. Let us know how that goes. We are always looking for improved methods for assembling these old engine.
Cheers
Henry Schmidt
Ph: 760-728-3062
Old 10-15-2010, 08:39 AM
Why would it be necessary to put any sealant on the bearing saddles?
These is no leakage path and the sealant should not stabilize the saddles.
I have been told it should not be done.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 10-15-2010, 04:49 PM
I have articulated and documented the theory of shear resistance offered by LocTite 574 flange sealant. I have illustrated in previous posts the movement called shuffle that occurs where the case halves come together at the main webs. There is absolutely no down side to properly applying Loctite to the main webs.
The choice is yours.
One additional thought: Shuffle is a real issue in a high performance Porsche engine that can be best addressed by methods like shuffle pins or hollow dowels. That said, anything that can add to the stability of the engine platform is a good thing and we have first hand experience that gluing the webs reduces shuffle.
Henry Schmidt
Ph: 760-728-3062
Old 10-15-2010, 05:00 PM
Tags
case sealants
