Grub screw?
Rebuilding my engine and trying to remember where this bit came from. Anyone recognise it? Cheers
http://forums.pelicanparts.com/uploads26/PXL_20220101_1457406201641070451.jpg[/img]
Old 01-01-2022, 11:54 AM
Puny Bird
Mark Henry's Avatar
You clipped the front code off your linky...fixed it for you.
Plus it's the grub screw from a shift rod linkage.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 01-01-2022, 12:22 PM
You probably have two of those. Screw them into the shift rod linkage now with a spot of thread glue, so as not to lose them.
Sent from my SM-G988B using Tapatalk
Old 01-01-2022, 12:55 PM
Puny Bird
Mark Henry's Avatar
^ agree
You're suppose to replace them every time, there's a little nylon button in the screw threads, one use only.
I clean the threads, use what ever loctite I have (red) and warm the screw up with a torch before removing it.
There's an easy release I've used (blue) and it works as well, the trick is those clean threads.
Old 01-01-2022, 01:12 PM
Brilliant! Thanks all, I was scanning the parts diagram but couldn't find it. Thanks for the advice on reusing it.
Cheers Jack
Old 01-01-2022, 09:28 PM
Grub screw
Actually the one to use is 65-68.It has a square 8mm head with a hole for safety wire.No loctite needed.Fred
Old 01-03-2022, 03:18 PM
