Can you put intermediate / distr gear on GT3 crank
Thinking of next rev of my motor and was wondering if you can put the intermediate shaft gear w distributor gear on a GT3 crank?
One less thing I'd need to change if I can keep the twin plug dizzy. |
Try not, Do or Do not
You can with some simple machine work. I'm not at the shop so I can't remember the exact process but it can be done.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
TTT - any details? Looking at this and want to understand what I need to ask of machinist, if anything?
(man/dude)
I think it's pretty simple. In the GT3 application it has a spacer instead of a distributor drive gear.
Note the 959 part number!!! Also the 901 part numbers in there, too.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Interesting. I've heard that it drops right in but have also heard from others there is some machining required - just want to get the final answer
