Twin plug lower spark plug connectors?
Is there a good source for longer Beru (or other) spark plug connectors that will fit the lower valve covers? The top ones are a bit short to be used at the bottom.
I know Clewett and stock 964 wires would work, but I'm looking for a removable connector so I can make my own wires. What do you all use for the lower spark plugs? |
Stock ones work fine. If u have turbo lower covers a bunch of the ribs need machining.
Stock connectors with ribs notched.
Rick 1978 911SC |
Thanks Rick, the second picture with the notched ribs is helpful, I'll do the same.
Check out the Clewett plug wires/connectors.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
