Twin plug lower spark plug connectors?
Is there a good source for longer Beru (or other) spark plug connectors that will fit the lower valve covers? The top ones are a bit short to be used at the bottom.
I know Clewett and stock 964 wires would work, but I'm looking for a removable connector so I can make my own wires.
What do you all use for the lower spark plugs?
Old 05-24-2023, 06:37 AM
Stock ones work fine. If u have turbo lower covers a bunch of the ribs need machining.
Old 05-24-2023, 04:04 PM
Stock connectors with ribs notched.
Rick
1978 911SC
Old 05-24-2023, 04:19 PM
Thanks Rick, the second picture with the notched ribs is helpful, I'll do the same.
Old 05-26-2023, 05:19 AM
al lkosmal's Avatar
Check out the Clewett plug wires/connectors.
RGruppe #669
http://www.x-faktory.com/
Old 05-29-2023, 09:19 AM
