IDA Weber carbs
Does anyone know where to have work done on a 911 IDA Weber carb. My air-mixture screw broke inside and need to have it repaired.
Thanks Hipdoc |
Under the radar
Picture? I found that p a r t s k l a s s i k .com has Weber parts. BTW, I don't see Pelican having them.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 05-02-2022 at 07:36 PM.. |
A machine shop might not be a bad idea. There are lots of porsche specific machine shops in CA that would be real familiar.
Daniel
it's not leaking....it's just marking it's territory |
What’s the name of the machine shop(s) in CA that could tap it out?
Under the radar
Post a picture. I bet one of the experts here will have a solution. But we need to see exactly what you are dealing with.
You might try Aase Motors (704) 770-8187 - 1104 E. Elm Avenue, Fullerton, CA 92831. Alan is their motor man and is terrific. Good luck.
'71 914-6 #0372 '17 Macan GTS |
Puny Bird
Jerry's Broken Drill & Tap in Santa Ana. EDM, they can burn it out without damaging the surrounding metal.
https://brokentap.com/ https://www.youtube.com/watch?v=8VvLJWkFGIw
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. Last edited by Mark Henry; 05-03-2022 at 07:23 AM.. |
Try not, Do or Do not
Generally we only do complete restorations on MFI throttle bodies, Solex and Weber carburetors. We can fix almost anything.
The question is: do you want them restored?
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
