Irrationally exuberant
ChrisBennet's Avatar
964 intake on 3.4 motor?
Is there any advantage to running a 964 intake "spider" on a 3.2 converted to 3.4L? have and extra 964 intake plenum and I thought I might try it on my 3.4 (twin plug, 10.5:1CR). I know there will be a bit of programming involved, I'm just curious if there would be any benefit.
-Chris
Old 05-24-2003, 05:30 PM
Bill Verburg's Avatar
I believe that you will have a tough time adapting the 3 bolt 964 manifolds to the older style 2 bolt head studs. Though I suppose anything is possible w/ enough effort. 964 head won't work either because of the incresed stud spacing.
I believe that the usual advice is to use TWM( or equivalent) or have the stock manifolds cleaned up(extrude hone?) to equalize flow through the various runners.
CamB. has( I believe) an interesting varient w/ mfi stacks serviced by Motec
Bill Verburg
Old 05-24-2003, 06:20 PM
Thanks Bill,
I'm not so much interesting in the mechanics of doing it, so much as whether the runners are too big. The motor is running 3.2 Motronic.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-25-2003, 02:03 AM
I see Smart Racing sells adapters for mounting 3.6 intakes on an earlier motor. Their catalog says they developed it for a 3.4 motor they project they did.
-Chris
Old 05-26-2003, 05:13 AM
bump
Old 05-28-2003, 08:35 AM
bump, c'mon anyone?
Old 06-02-2003, 06:27 AM
Roslin's Avatar
Hi Chris, I thought about the same, but on a 3.0 engine instead, But my idea was to Design and machine complete new Flanges from a 3D model, and made a cone or radius inside to blend from Head Diameter to ( in my case ø39 ) to The internal diameter of the 964 runner .. What did your experiment end up with ? do you know the internal diameter of the 964 runner where these are connected to the flange ?
Roslin
Porsche 911 SC 3.0
Old 11-24-2008, 05:06 AM
Roslin
I wound up not going that route. I really doubt that mixing 3.6 intake with a 3.0 motor would be a good match. I think someone was tinkering with the idea of using a Boxster intake but I don't know what came of it. You could do a search.
-Chris
Old 11-24-2008, 06:34 AM
rsscotty's Avatar
3.6 intake on 3.2 engine
We do this conversion with great results. Above should be 3.6 intake on 3.0 engine.
The billet adapters for the cylinder heads are in stock.
Rothsport Racing 503 885 9626 Jeff Gamroth
Old 11-24-2008, 06:09 PM
rsscotty's Avatar
Billet adapter 3.6 intake to 3.2 head
Old 11-24-2008, 06:17 PM
gumba's Avatar
What would be the advantage of running 3.6 intakes on a 3.2?
Old 11-25-2008, 05:54 AM
rsscotty's Avatar
Dyno :: 3.2 Stock with SSI exhaust / M&K muffler
Posted is a dyno sheet for a stock 3.2 Autothority chip SSI M&K muffler.
If you were to install a 3.6 intake with engine management you can expect gains in torque @ 4500=16+ ft. lbs. at 6000=24+ ft. lbs. horsepower gain @6100=26
above the graph numbers.
We have done many conversions on 3.0 liter engines with the 3.6 plenum, but this was to get rid of the CIS. We have yet to put a 3.6 plenum on a 3.2, but we have done one on a 3.4 race engine. The numbers above are projected gains based off of our 3.0 results.
Old 11-25-2008, 02:20 PM
Navin Johnson
TimT's Avatar
I wonder what the benefit would be if you used a varioram intake on a smaller displacement engine? i.e. 2.4-2.8?
'69 911 GT-5
'75 914 GT-3
and others
Old 11-25-2008, 03:20 PM
Jeff Alton's Avatar
Randy wells has a 2.8 with varioram and motec.......
Cheers
www.turn3autosport.com
Old 11-25-2008, 07:51 PM
911-32's Avatar
Do you know if Rothsport have adapters for fitting the 993 stacks/intakes to a 3.2 head? It will be the same type of adapter but with an internal taper running from 42mm diameter down to 39mm diameter? I have a 964 plastic intake, 993 plastic stacks and 3.2 heads - don't ask why!
If I might be so bold as to ask a couple more questions
- what have you done with the throttle linkage? Adapted the 3.2 rod system or replaced with a cable?
- your pictures shows an engine (presumably) running engine manaement as there is no AFM while the dyno plot is (presumably) for an AFM 3.2. Any issues putting the 3.2 AFM on the intake? my understanding is that the 964 and 3.2 AFMs are the same part, so I guess not.
- do you stick with the high impedence 3.2 injector and remap accordingly rather than use the low impedence 964 type injector?
- your adapter cover the cut-out in the 3.2 heads for the std injector placement by the look of it, do you fill the cut-out or just leave it covered over? It might have a tiny negative flow impact if you don't fill it but I can't get too excited about it.
- if you had a choice, would you keep the adapter as thin as possible and replicate as close as possible the original injector placement? or make it thicker to raise the injector placement?
Such a timely revival of an old thread. Very useful having the pictures and confirmation that it works on the dyno!
Thanks,
Richard
Old 11-26-2008, 03:37 AM
MBruns for President
JeremyD's Avatar
Wow - good to know - maybe I need to be shopping for a 993 intake?
Old 11-26-2008, 06:37 AM
North Coast Cab's Avatar
I have a 993 v-ram intake. I was going to replace my non-vram on my 993 but decided not. I'd love to see that set-up.
1985.5 944 GTS
Old 11-26-2008, 09:32 AM
Roslin's Avatar
Sounds great with the resulst from an 3L engine .. interesting ! But my idea was to produce onepiece injectorbody with 2 bolt pattern for the 3.0/3.2 cylinderheads, ( sory i wrote flange, but ment injector body) these should then be made to fit 964 or 993 runners, but with an corect designed ( acording to optimum flow) blend between head and runner corne or rasdius..
Porsche 911 SC 3.0
Old 11-26-2008, 09:36 AM
Roslin's Avatar
maby the varioram intake could be a good choice for smaller motors, seen from a midrange touque point of view ..?
Porsche 911 SC 3.0
Old 11-26-2008, 09:40 AM
Navin Johnson
TimT's Avatar
I think that by the time you got a v-ram setup fitted and dialed in on a small motor, you'd have been better off just installing a 3.6.
Now where is the challenge in that?
I can't install a 3.6 anyway, class rules etc. I'm thinking of building another engine, with IBTs and a varioram manifold, Haltech E11. currently I'm getting about 200 hp from a 2.2, If I can fatten up the midrange a bit that would be very helpful. The car weighs 1850#
And I have already a spare block, the engine managment, the ITBs and the varioram manifold.
'69 911 GT-5
'75 914 GT-3
and others
Old 11-26-2008, 11:55 AM
