Under the radar
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 06-30-2022 at 04:13 PM.. |
Racer
What do you you think is required when you need to vary load and RPM? You can’t do that in the garage. You can do that on an engine dyno, a chassis dyno, or by driving it.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Under the radar
My takeaway here is this.
Pre-oil the motor. Start and maintain at least 2000 rpm. When the oil reaches 140 drive normally, (varying engine speed), without heavily loading the motor, and maintaining an RPM range of 2000 to 5000. After 20 minutes, change the oil and adjust the valves. Drive normally there after.
Travis
Some great information here. Really appreciate all the sharing.
Thanks for all the info guys!
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/porsche-911-technical-forum/410787-drivetrain-project-complete-3yrs-pics.html Interior - http://forums.pelicanparts.com/porsche-911-technical-forum/452686-interior-refurb-carbon-fiber-71-a.html#post4433500 |
Is a valve adjustment really necessary at the end of that first twenty minutes? My thought had been to only change the oil after twenty minutes, and check rockers and valves at 1,000 miles.
1982 911SC |
Under the radar
BTW, I forgot to mention that I have modified cam oil restrictors. I drilled them out to 4.5 mm however, as mentioned here Camshaft oil pressure restrictors and in an older thread.
Perhaps during cam break-in no restrictor?
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 07-14-2022 at 07:46 PM.. |
Location: behind the redwood curtain, (humboldt county) california
John Dougherty liked this idea...
Hi Gordon,
I posed this same question to John Dougherty, (since we both have his cams), and he liked the idea of running the big stock restrictor for cam break in, but did not suggest a mileage change over point or size to go to. Looking forward to further input/clarification for the 2.8 hot rod build. chris |
This video seems to suggest breaking in cam first then going for a drive to break in rings....hmm.
https://youtu.be/MhA_nVRhYew?si=gFfFw8MaoMy638l6 |
Racer
Man this topic confuses me.
I guess I had always figured the 20 minutes at 2000 rpm with no load was to break in the cam without any load on the rings - preserving them in their "rough" state until the cams were broken in. Then, get rid of the cam detritus via an oil change and then get on with breaking in the relatively "unmarred, untouched" rings via a drive with varying load and rpm. I don't know what I will do with my 3.4 but by default I am following Wayne's book... D. |
Yeah, I guess I was assuming this thread was mostly people who were going to be breaking in their engines in car not on a dyno. Last edited by Chris78; 11-03-2023 at 03:54 PM.. |
Chain fence eating turbo
You can always get rings to seat later (unless something is really amiss), you can't always get your cam lobes back.
Cam break-in, IMO is more important.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
It's a 914 ...
Does delaying the ring break-in procedure (to do the cam break in procedure first) compromise the end result?
Racer
I know that I am more concerned with seating the rings than I am with bedding in the cams and rockers...mostly because I keep the engine above 2000 RPMs for at least 20 minutes during the initial engine break in process...
C. Last edited by Chris78; 11-11-2023 at 11:46 AM.. |
