993 cylinder base seal issues
Anyone else had issues w/ oe 3.6(not 3.8) cylinder base seals?
I'm being told that the green Victor Reinz are not the ones to use, Wrightwood are but seem to be difficult to obtain a black flattened version is also available and preferred
Try not, Do or Do not
Supertec sells Wrightwood but a better solution is an internal groove cut in the spigot that holds an o-ring that compresses against the cylinder.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
As you mention, no on VR. Wrightwood kits are superior.
I saw a 3.6 have to come apart again after a "reseal" with VR at a local shop. It leaked like a sieve. Was put back together with a Wrightwood. If our host doesnt have it Henry can help or EBS. Last edited by superninety; 09-03-2022 at 02:51 PM.. |
Sealing the 3.6 base can be a challenge but the popper o-ring with a small amount of Curil T is nice insurance.
Does that make any difference?
Mike
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
We are using the T2. I think you'll find that it gets thicker after you squeeze out a small amount.
thank you.
