Bill Verburg's Avatar
993 cylinder base seal issues
Anyone else had issues w/ oe 3.6(not 3.8) cylinder base seals?
I'm being told that the green Victor Reinz are not the ones to use, Wrightwood are but seem to be difficult to obtain
a black flattened version is also available and preferred
Bill Verburg
Old 09-02-2022, 07:04 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Supertec sells Wrightwood but a better solution is an internal groove cut in the spigot that holds an o-ring that compresses against the cylinder.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-02-2022, 04:19 PM
superninety's Avatar
As you mention, no on VR. Wrightwood kits are superior.
I saw a 3.6 have to come apart again after a "reseal" with VR at a local shop. It leaked like a sieve. Was put back together with a Wrightwood.
If our host doesnt have it Henry can help or EBS.
Old 09-03-2022, 02:47 PM
Sealing the 3.6 base can be a challenge but the popper o-ring with a small amount of Curil T is nice insurance.
Henry Schmidt
Ph: 760-728-3062
Old 09-05-2022, 09:58 AM
To further possibly complicate things the case is an '89 964 while everything else is 993
Does that make any difference?
Bill Verburg
Old 09-06-2022, 07:30 AM
Henry, I see that Curil T is being replaced by Curil T2... which seems to be a more "runny" texture... Have you used the newer version? Can it be used in all the places we normally used the original Curil T?
Mike
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 09-08-2022, 10:27 AM
Cases and cylinders are basically the same.
Mike
We are using the T2. I think you'll find that it gets thicker after you squeeze out a small amount.
Henry Schmidt
Ph: 760-728-3062
Old 09-08-2022, 10:53 AM
thank you.
Always learning.
Old 09-08-2022, 10:59 AM
