I hadn’t seen this before…
The oi pressure sender in the lower oil gallery required some work. You have to remove the plug and tap with appropriate threads (or in this case maybe close). plenty of solutions with pressure light and sensor in one to avoid doing this.
john |
Racer
You mean like in this photo??
![]() Not an uncommon location....and better than the breather cover.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Give someone a tube to squeeze, how do you tell them, don't squeeze too much??? |
Just think of the cleanup, it’ll peel right off…except in the oil galleys, rocker oilers, the piston squirters, on and on.
Bruce |
![]() You can get early and late (993) senders that have a oil pressure switch for the light and a sender for the gauge all in one. That would have been easier than tapping front for sender. ![]() john |
I have a supposed 4.0l built by MotorMeister that will be disassembled early next year. I'll bring you guys on the road to discovery as it comes apart
Here is the one I mentioned earlier "rebuilt by pro shop" with cylinders on upside down and 2 piece return tubes.... Motor had about 1000 miles on the "rebuild"....
![]() Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
https://www.vdo-instruments.com/sensors/pressure-senders-switches/pressure-sensor-with-warning-contact.html For example, 360-023 is a combo switch/10 bar sensor in M10x1.0 that O'Reilly list for less than $40. Mine says "Made In Germany" on the packaging.
'77 S with '78 930 power and a few other things. |
Thanks! |
The two piece are the only solution to replace leaking ones on a motor that is not coming apart, so they do serve a useful purpose. When rebuilding we only use OE one piece steel ones. Others may have differing opinions mind you.
Cheers
I always enjoy solid return tubes for look and function
Got boxes of split ones used, don’t know why…. Bruce |
Try not, Do or Do not
We've been running a double sending unit for decades. To clean up the wiring we make a custom harness.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Screwing a late sender directly into the case is new to me. I like that option.
Allows for a late double to be fitted. Moving the sending from the front of the case to the rear cleans up the cam feed lines as well.
Thanks in advance! D. |
I bought 10 bar sensor because that's what my gauge uses/appropriate for 930 oil pump output. I'm fairly confident input impedance on the Motec wouldn't mess with the gauge reading too much if you were to "tee" the original sensor - but for $40, you can add an extra sensor and leave the gauge entirely alone. Pretty sure M10x1.0 matches the factory pressure switch fitting from what I've read.
D. |
Ha! Nice thread Bruce!
More of the messy.. in the process of tearing down 3.2 and find these "unique" RSR rocker seals, aluminum washers on case thru-bolts, and silicone as case sealer everywhere! ![]() ![]() ![]() ![]() ![]() ![]() ![]()
RGruppe #180 So many cars.. so little time!! |
...here in Czech we have some special guy working on 911..and others..it is lovely-NOT to do jobs after him..red silicone everywhere-the time to clean it takes longer then assembly of the engine;-)
The latest is the best ,crushed oil tube on camshaft housing after he put mismatched cyl and piston on engine he rebuild..price( i know that one) $8K...oh well garage is full .time to go to work..oh ya bent valves btw, thanx again John W. the mid pic is 993 ..had to do service, nightmare it was ![]() ![]() ![]()
1985 911 with original 501 761 miles...807 506 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 11-22-2022 at 01:14 PM.. |
well? i just got in 1973 engine from USA ...(do not know where has been) but some genius put in chain tensioners update kit-lovely...since the chain were too stretched he figured out this--never mind all brown rails...camshaft shims and oil shim upside down..
1985 911 with original 501 761 miles...807 506 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
