Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Try not, Do or Do not
Hi Jeff, this suggests you know the M1 cam specs....care to share?
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Cheers
I think the fact it is designed to work on a stock CIS motor, lends to the idea that perfomance is left on the table, seeing as the owner is using programmable efi and ITBs.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
What is a Knight Race 45 cam?
Given Davids design components and performance requirements, DC30 seems apropos. Nothing crazy but give the parameters, this build should be fun to drive.
PCA Member since 1988
Back to the M1 cam: I haven't got my car on a dyno yet to do the final tuning, so I don't know what the numbers are. I will post those after I do that. That said, I do know from my measurements as I timed the M1 cam that it uses all the room available for lift and duration on 3.0 and 3.2 engines without the valves hitting the pistons. Therefore, one has to stay very close to the recommended cam timing, because retarding or advancing the timing more than a few degrees, WILL result in cam/piston interference. I measured that. So, yes, "it leaves performance on the table" IF you want higher RPM power, but are willing to give up low-mid RPM torque.
If you choose different pistons with valve pockets, you can choose a more "radical" cam, but you will give up low RPM torque and smoothness. As Henry observed, to a racer, high-RPM power is most important, but a high-RPM engine is a lousy street driving experience. What the M1 does for a street car is give a wide range of torque. As I noted before, I have retained CIS on my car, and I can floor the gas pedal at just above idle, in the higher gears, and it will pull smoothly all the way to redline. I like that for a street car, especially with the crappy-shifting 915 transmission. I also get close to 30MPG at constant highway speed. Not shabby for an old engine design. Even if I don't get to my desired 230 RWHP @6000RPM in my tuning, I like the driving characteristics enough that I would build another engine with it.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 03-21-2023 at 11:18 AM.. |
I got the fuel distributor back and installed and running but I only have 200 miles on it so I have not gone above 4000 RPM yet and can not tell what the butt dyno says. I did a Kermit clone CIS set up and it starts better loosing the WUR. I have Carillo pistons with big valve cut outs so I could have gone to a much bigger cam than the M1. With no shims under the cylinders I came up with 9.75:1 CR. and 4mm VtoP clearance but the VtoV clearance was VERY close at overlap. Nice and smooth pulls to 4k but that is not saying much yet.. I built this 3.2ss to be a good cruiser going up and I-95 at 28mpg, I optimized Henry's advice on shooting for friction reduction rather that all out power.
I'm not picking my nose..I'm porting my upper intake manifold. |
For some reason I double posted. But the M1 has SC/Carerra lift with increased duration only.... Cheers
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
The engine gods have touched me..last night, I'll get right on it today after I change out the rear wheel bearings with 350k on them.
Without a reasonable amount of overlap, performance is always/generally compromised. I added generally because "always" is a trigger for dissension. In this conversation, understanding cams in their simplest terms seems beneficial. To add perspective as I understand lobe center: Changing the lobe separation changes the amount of overlap that exists during the time the intake and exhaust valves are both open. On a naturally aspirated engine, the lobe separation angle has an effect on whether the engine reaches peak torque a little earlier or later in the rpm range. Typically, narrower lobe separation develops peak torque at lower rpm and widening the separation tends to build peak torque higher in the rpm range. If a street car has smaller lift and duration numbers, they might run 106 or 114. Widening their separation angle helps increase upper rpm power output. Alternatively, if you are running a bigger camshaft to gain maximum top-end power, cam makers often suggest reducing the lobe separation angle to recover power lost in the lower rev range.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 03-22-2023 at 05:54 AM.. |
To add what Henry stated about LSA. Lower LSA's will make the torque curve more "peaky." Widening the LSA will broaden the torque curve, but the peak torque output will be lower. Lower LSA's will increase torque at lower RPM's, but will also reduce engine vacuum and idle quality (important if you have power brakes). Lower LSA = lower RPM for peak torque, but decreased idle quality. Higher LSA = higher RPM for peak torque (and usually lower peak torque output), but increased idle quality. The higher LSA cam will make more peak HP than the lower LSA cam at the expense of reduced peak torque output.
If it has boost, the turbo/supercharger will forgive a lot of the sins with respect to torque output that the wide LSA cam tends to have. Boost and a wider LSA go hand in hand and tend compliment each other. If you run a really narrow LSA with boost, some of that boost will go right out the exhaust during overlap, wasting fuel and reducing power. |
The only thing I know are '83 CIS cams. 964 cams are good but William says they are still a CIS emissions cam and the M1 is a max cam for CIS pistons, so there are MANY other cams to choose from that are bigger. I have Carillo pistons with lots of P to V clearance could have gone much bigger, instead I could get rid of the under cylinder shims and squeeze 9.75 out of the stock heads. I picked the M1 so it would not tear up a stock valve train because that is where problems start. The only spec I know is the lift comes out to 11.4 mm from setting the valve timing and set it at 2.2mm which is mild. Good, that's what I wanted, my engine had 350k on it and all the cylinders were at 150 PSI static but it was tired. Performance and reliability and diametrically opposed so when we dream up engines it is good we have William, Henry and Neil to ask to help. Henry made an impression on me with the 3.2ss is well sorted and output documented and the way to go was friction reduction, so that was the path I did, very expensive to get all the parts coated but it does spin nice.. the car jumps but is that from 40% reduction in rotating mass or the bump in displacement or the M1 cam? It doesn't hurt that the cam was designed with a chick that was at Ferrari..
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
I used Industrial Hard Coatings of Denver NC. They do all the NASCAR teams DLC coatings.
Call 911
Why not use wide LSA cams and retard timing a few degrees to pick up the top end? Wouldn't this be a good compromise for those running manifold fuel injection systems?
Dave Kirk My Porsche restoreth my soul. |
The DC40 is a great match for carbs. Carbs really like overlap. The stock SC cam is not optimal. I also ran a DC20/19 cam, but that wasn’t much better than the SC. The carbs didn’t tune as easy with these two compared to the DC40 JE pistons needed to have the exhaust valve pocket cut 0.025” deeper to get the minimum acceptable clearance with the DC40. Getting the pockets cut at a machine shop was easier than I thought. And maybe $150? |
