Hard to argue with the “look” of trumpets, but I’ll be dammed if your motor doesn’t look great.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 03-31-2023, 09:39 AM
Speaking of looks Jac, still waiting to see those 7" aluminum steelies I sent you last year on your ride.
Old 03-31-2023, 09:52 AM
Jeff Alton's Avatar
Originally Posted by jpnovak View Post
I have installed and worked on a bunch of different ITB setups. here are some of my thoughts.
PMO
-Easy to install and balance
-Linkage arms often need considerable adjustment to have same arc travel balance on each side.
-Good airflow
-Can use KN watershield air filters
-Can buy as ITB only if you are converting from Webers. Uses same manifolds and linkage.
Borla (formerly TWM)
-Good airflow
Triumph Triple
-Budget adaptation
-Limited injector selection
-linkage is usually terrible.
Jenvey
-work well
-IMO Linkage is not easy to setup. But works well once going.
-Look very much pieced together.
-Challenge finding good filters for stacks.
RHD
-Linkage works well.
-Easy to setup and balance.
I have not tried AT or JSR but they both look very interesting to me.
On a street car you will not noticed the difference between most of the readily available ITB setups. The end result will be your ECU choice and more specifically the tuner that completes the installation, setup and tuning process. This is where you get excellent or mediocre results.
for a street car I would make sure you have good filtration. There are many examples of cars with open stacks. This is just asking for water or dirt ingress leading to damage. I am not a fan of the snap on "mesh filters". to me they rob too much power.
Jamie, I find it odd that you had trouble sorting filter options for Jenvey and RHD, as they offer them....
The Jenvey's do require a few extra minutes getting them dialed in, but then are very stable and repeatable. To date, they have been our "go to".
The PMO, not sure if you can even get them even after the EMPI aquisitsion, used all Weber compatible parts. The manifold was the biggest detractor...
Cheers
www.turn3autosport.com
Old 04-01-2023, 09:18 PM
Originally Posted by OSC911 View Post
I went with the Rasant kit - Motec M84, PMO and milspec harness. Really nice gear but the lead time was quite long and the tech support was pretty average.
If I had my time again, and knowing that Clewett are now using the Haltec ECU range, I would definitely go with them, just for the support they are known for. I don’t have any experience with his new ITB, but they look great.
Did you recently pick this up and if so where were you able to get it from?
Thank you
Sent from my Pixel 6a using Tapatalk
Old 04-04-2023, 07:40 AM
Racer
winders's Avatar
Here are my "drive by wire" AT Power ITBs.....
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 04-04-2023, 10:47 AM
PCA Member since 1988
Looks great!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-04-2023, 11:07 AM
al lkosmal's Avatar
RHD with rainhats
RHD with rainhats......
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 04-07-2023, 10:26 AM
al lkosmal's Avatar
More RHD w/rainhats/filters.....
regards,
al
RGruppe #669
Old 04-09-2023, 10:42 AM
regards,
al
That runs very smooth.. which cam is it running?
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 04-10-2023, 03:21 AM
al lkosmal's Avatar
Mike,
That's a 3.2SS with Webcam Mod-S cams.
regards,
al
RGruppe #669
Old 04-10-2023, 09:40 AM
H-viken's Avatar
Originally Posted by Henry Schmidt View Post
We make our own but they are still in testing. Not ready for prime time.
New twist on an MFI design.
The manifold were cast using old Mahle pistons.
Hi Henry
What’s the article number of that ITG filter? Are you using the standard baseplate or have you cut it yourself?
Curious to know the measurements
Cheers!
Johan
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 04-11-2023, 04:28 AM
Turbonut
Raceboy's Avatar
Good overview of available kits from Jeff.
I made my own conversion using GSXR throttles, custom manifolds and linkage. Used Pipercross filters and CNC cut custom filter backplates. Definitely not too easy but it iw working great.
Regarding idle air, with electronic throttle setup there is no need for such thing. DBW compensates for cold starts, any higher load at idle (for example high beams etc), always perfect idle like normal car.
Plus one can have custom pedal vs throttle opening profiles, helps traffic driving tremendously.
I used BMW E46 M3 (S54B32) throttle actuator and BMW E46 throttle pedal. VEMS ECU controls everything.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 04-11-2023, 10:07 PM
Racer
winders's Avatar
These are some of the things I am really looking forward to with my new DBW setupfor my race car. No more having to sit in the car to keep it running until it warms up. Just start the engine and forget about it. I'll set idle speed based on head temperature via the MoTec M150.
Being able to control the throttle using a progressive curve of my choosing is going to be awesome!
Scott Winders
PCA GT3 #3
Old 04-11-2023, 10:21 PM
Travis
I ran Andrews kit for a year and we had a major issue with the AEM brain and his crank sensor. I then swapped (my cost) the AEM for a Motec which helped but still wasn't perfect. I would agree, the service was not great, and then out of nowhere Andrew just closed shop.
Buy based on service, these are not plug and play systems.
Old 04-12-2023, 05:17 AM
Mark at Exotech just did RHD throttle bodies, COP, and a MaxxECU on my 3 liter for my 914. It's wild to just reach in and hit the start button. The car starts immediately and just idles. He has to finish tuning it, but it was really fun at Summit Point this weekend!
The Maxx is really powerful. I have future plans for DBW, but that is a ways out.
Old 05-02-2023, 06:17 PM
JmuRiz's Avatar
Nice!
'73 2.0 914 (2.8 /6 conversion in progress)
'64 356SC
'65 Ducati Falcon 80
‘19 Audi SQ5
Old 05-03-2023, 06:52 AM
r_towle's Avatar
Curious, what are the pro/con of a centralized TB and plenum versus ITBs?
Rich
Old 05-03-2023, 12:42 PM
Rich
For one and it’s a major one - the 964 setup is easier to tune as there are less variables to deal with.
Old 05-03-2023, 01:11 PM
I won't claim to be an expert, but Mark at Exotech had my car start, idle, and drive very quickly without trouble. The on track tuning was close and he is getting that dialed in really quick. As a customer, I don't think the ITB made it any harder.
Old 05-03-2023, 01:13 PM
targa72e's Avatar
When using a common plenum with a single throttle body you are limited to cams with small overlap. When there is large cam overlap and a common plenum the air/fuel mixture will be blown back into the intake at idle and low speeds making for a poor running car. Because ITB's and carbs have a throttle plate over each cylinder that is closed at idle they keep the aif/fuel mixture from being blown back up the intake. This allows you to have a more aggressive cams and still have a car that will idle and run well at low rpms. So cam choice can dictate what type of intake you use.
john
Old 05-05-2023, 12:26 PM
