Hard to argue with the “look” of trumpets, but I’ll be dammed if your motor doesn’t look great.
Ass-engine Nazi slot car -- PJ O'Rourke |
![]() The Jenvey's do require a few extra minutes getting them dialed in, but then are very stable and repeatable. To date, they have been our "go to". The PMO, not sure if you can even get them even after the EMPI aquisitsion, used all Weber compatible parts. The manifold was the biggest detractor... Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Thank you Sent from my Pixel 6a using Tapatalk |
Racer
Here are my "drive by wire" AT Power ITBs.....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
PCA Member since 1988
Looks great!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
RHD with rainhats
RHD with rainhats......
![]() regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
More RHD w/rainhats/filters.....
regards, al
That runs very smooth.. which cam is it running?
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Mike,
That's a 3.2SS with Webcam Mod-S cams. regards, al
What’s the article number of that ITG filter? Are you using the standard baseplate or have you cut it yourself? Curious to know the measurements Cheers! Johan
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold Last edited by H-viken; 04-11-2023 at 04:31 AM.. |
Turbonut
Good overview of available kits from Jeff.
I made my own conversion using GSXR throttles, custom manifolds and linkage. Used Pipercross filters and CNC cut custom filter backplates. Definitely not too easy but it iw working great. Regarding idle air, with electronic throttle setup there is no need for such thing. DBW compensates for cold starts, any higher load at idle (for example high beams etc), always perfect idle like normal car. Plus one can have custom pedal vs throttle opening profiles, helps traffic driving tremendously. I used BMW E46 M3 (S54B32) throttle actuator and BMW E46 throttle pedal. VEMS ECU controls everything.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet http://www.facebook.com/vemsporsche |
Racer
Being able to control the throttle using a progressive curve of my choosing is going to be awesome!
Travis
Buy based on service, these are not plug and play systems. |
Mark at Exotech just did RHD throttle bodies, COP, and a MaxxECU on my 3 liter for my 914. It's wild to just reach in and hit the start button. The car starts immediately and just idles. He has to finish tuning it, but it was really fun at Summit Point this weekend!
![]() ![]() The Maxx is really powerful. I have future plans for DBW, but that is a ways out. |
Nice!
'73 2.0 914 (2.8 /6 conversion in progress) '64 356SC '65 Ducati Falcon 80 ‘19 Audi SQ5 |
Curious, what are the pro/con of a centralized TB and plenum versus ITBs?
Rich |
Ace of Spades
I won't claim to be an expert, but Mark at Exotech had my car start, idle, and drive very quickly without trouble. The on track tuning was close and he is getting that dialed in really quick. As a customer, I don't think the ITB made it any harder.
When using a common plenum with a single throttle body you are limited to cams with small overlap. When there is large cam overlap and a common plenum the air/fuel mixture will be blown back into the intake at idle and low speeds making for a poor running car. Because ITB's and carbs have a throttle plate over each cylinder that is closed at idle they keep the aif/fuel mixture from being blown back up the intake. This allows you to have a more aggressive cams and still have a car that will idle and run well at low rpms. So cam choice can dictate what type of intake you use.
john |
