Timing chain guide rail
Hi,
I guess this chain rail is installed the wrong way. So here’s the question: what will be the consequenses running the engine with the rail this way ? I am asking because the rail is installed like this in a friends engine that already is in use. Cheers This picture is from when the engine was "rebuilt". ![]() Sent from my iPhone using Tapatalk Last edited by Classic 911; 05-20-2023 at 09:26 AM.. |
Just turn it around and carry on.
Does it matter?? Could it break? I’d make it right especially if it was my mistake. Parts for these motors are way too expensive. Any failure you’ll get blamed regardless.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Try not, Do or Do not
Installing it backwards might create premature sprocket wear but it's doubtful.
Simple rule of thumb when installing chain rails in early 911 air-cooled engines is: The long leg points to the nearest sprocket.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 05-20-2023 at 09:20 AM.. |
It's a 914 ...
It's possible to pop off the chain box cover and flip the rail if I'm not mistaken. Can be done at next oil change.
[QUOTE=
Simple rule of thumb when installing chain rails in early 911 air-cooled engines is: The long leg points to the nearest sprocket.[/QUOTE] I’ll remember that little bit of info. Thanks Henry |
Get a new one ready because the retaining tab can break off on removal.
