Timing chain guide rail
Hi,
I guess this chain rail is installed the wrong way.
So here’s the question: what will be the consequenses running the engine with the rail this way ?
I am asking because the rail is installed like this in a friends engine that already is in use.
Cheers
This picture is from when the engine was "rebuilt".
Old 05-20-2023, 05:44 AM
Just turn it around and carry on.
206 637 4071
Old 05-20-2023, 06:05 AM
Thank’s for answering John.
The case is that the engine is already in use, hence the question
Old 05-20-2023, 06:07 AM
Does it matter?? Could it break? I’d make it right especially if it was my mistake. Parts for these motors are way too expensive. Any failure you’ll get blamed regardless.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 05-20-2023, 09:09 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Installing it backwards might create premature sprocket wear but it's doubtful.
Simple rule of thumb when installing chain rails in early 911 air-cooled engines is:
The long leg points to the nearest sprocket.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-20-2023, 09:18 AM
It's a 914 ...
stownsen914's Avatar
It's possible to pop off the chain box cover and flip the rail if I'm not mistaken. Can be done at next oil change.
Old 05-20-2023, 12:26 PM
[QUOTE=
The long leg points to the nearest sprocket.[/QUOTE]
I’ll remember that little bit of info. Thanks Henry
Old 05-20-2023, 04:55 PM
Get a new one ready because the retaining tab can break off on removal.
206 637 4071
Old 05-20-2023, 05:10 PM
