PRO Motorsports
Tyson Schmidt's Avatar
Who's boring plastic MFI stacks?
I need to get a set of plastic 911T MFI stacks bored out to S/RS size.
I asked Henry at Supertec a while ago and apparently Aaron stopped doing it, and I don't know where else to turn.
Anyone else doing this?
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 06-06-2023, 02:26 PM
Eurometrix maybe. Ask Mark Jung, 356rs.
206 637 4071
Old 06-07-2023, 07:57 AM
BURN-BROS's Avatar
Big changes for me , but I will resume this work this year. I’ll send out updates when I’m set up.
Old 06-07-2023, 07:18 PM
BURN-BROS's Avatar
I’ll be moving into Retro-Sport’s 15,000 Sq feet of Porsche goodness located in the San Francisco Bay Area! Lots of work ahead to move in and get up and running.
Old 06-07-2023, 07:57 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Great to hear.....it seems like I may have as many as ten sets waiting for the rocket man to return to earth. The Porsche world that is.....
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-08-2023, 05:49 AM
PRO Motorsports
Great to hear! Now take my money.
2004 GT3
Old 06-08-2023, 04:06 PM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
May be able to help ..
Old 06-09-2023, 04:41 PM
As much as the "Return of Aaron" is exciting, we're designing some tooling to make boring these stacks possible with our limited equipment.
We have a crazy inventory of MFI stacks, butterflies and pumps that need to find some updates to make them more adaptable to popular builds.
Henry Schmidt
Ph: 760-728-3062
Old 06-11-2023, 09:35 AM
gearhead
I’ve got a set that were done by Mike Bruns that I’ve been thinking of selling. We should talk.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-11-2023, 02:00 PM
If there is going to be a considerable demand and sounds like Henry may provide that, a CNC program would I suppose be justified. If you are just doing one, the only piece of equipment needed is a mill. I realize everyone doesn't have one, But in the various gear head communities, bet someone has one. I bored out a set of 2.2 mag stacks to 47-40 for a 3.0 track motor. My method was crude and primitive, counter to standard machining principals, time consuming, but I was amazed at the finished product. A very rigid fixture for the stack assembly, a 18'' sturdy boring bar, a fixture for a 1'' spherical bearing to support the bottom of the bar while the top is held in the spindle. All of these are made by you. The bit was 1'' with a taper to match the angle of the stack bore. Dropped it in 1'' at a time and made lateral adjustments to the bit for each cut. Finsished up with 3 tapered hones with 3 different grit surfaces. Very time consuming but the plastic stacks should be easier. Bob
Old 06-20-2023, 04:02 PM
I am pretty sure that Karl at Thoroughbred Motorsports in Corty PA has tooling to do this.
Old 07-19-2023, 09:12 PM
PCA Member since 1988
Stacks would also be a good candidate for 3D printing.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-20-2023, 01:02 PM
