Need Recommendation valve job in So. Cal area
Any recommendations for valve job on 911 heads in So. California?
Many machine shops said they will do it but I would like to find one that specializes or does a lot of 911 heads. |
I just had mine done by Steve Becker in Oregon. I like you could not find someone close who could. I called a high high end shop that must work on ultra high end stuff. He talked me out of using him and gave me Steve’s number. I didn’t even know he has the experience he has when I spoke with him. After I got his invoice, I found his webpage. Wow, good experienced guy does it all. I’m not sure if he is a one man shop. But does great work and i’m impressed. Highest recommendation and he reasonably priced. It’s worth the cost to ship to him. My service was clean, touch up valves and seats, new valve guides, set springs for my new 964 grind cams. He used my original valves and seats, springs, retainers, and keepers.
Becker6. com ![]()
Constitutional Liberal
Supertec is in So. Cal. Although they are known for building great engines, they also do all their own machine work.
Give Henry a call.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
@porschedude996
@Turbo_pro Thanks for the info will be calling them tomorrow. Any others in So. California area, got to be a few more out there. |
Competition Engineering. They have been doing machine work on these cars for 50+ years.
http://www.competitioneng.com/History.htm Can't recommend Walt highly enough. |
Try not, Do or Do not
We are closed on Mondays....trying to live our best lives.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 09-12-2023 at 08:47 AM.. |
I find it funny that when I was looking for a P-Car machine shop I could trust, I couldn’t find one. Now that I’ve sent item out I find more and more capable people.
Stevie B and I worked together at Andial in the race engine dept., building the race engines. After leaving he went and worked for his dad running their high end CNC shop. Steve moonlighted in my shop often when we needed more machinists. Since then, he represents PD on the West Coast with machine work and builds. That includes head work, Engine Case work, including line bore repair.
I highly recommend him as he does work at our level. |
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Call Henry Schmidt Outstanding quality work.
