Is it OK to re-use main bearings?
Hi guys,
I decided to split the case to check my main bearings after I was shocked by 1 destroyed conrod bearing, I had a relief when I saw the bearings in what appears to be good conditions and more importantly good crankshaft journals as well, please have a look at what the bearings appeared to be and let me know if its fine to re-use them? .. I'm saying that because I have ordered a set of main bearings from Rosepassion.com and they send me a box that has no brand name on it, even the bearing shells themselves have no marking at all except the part number so I thought maybe its better to keep the original Porsche bearings.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management.
-1987 Carrera Coupe.
-2013 Carrera S PDK Coupe, factory Aero Kit. My DD.
-1987 928S4.
Old 02-17-2024, 10:38 PM
PCA Member since 1988
Yes.
I have now come to prefer excellent used bearings, after checking them with Plastigage. Certain brands of recent bearings have had quality problems.
It is hard to assess bearing condition with just pictures, however, your "7D" bearing looks like it has some mark above the "D" and some of the others look like the surface is not smooth. That might just be oil or grease, Make sure they are perfectly smooth and the plastigage ends up between .01mm and .07mm. I think .05 is ideal.
If you have any doubts, make sure a COMPETENT machine shop looks at it and measures the clearance.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-17-2024, 10:51 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Yes, if your budget dictates.
They (good used bearings) are excellent candidates for dry film coatings.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-18-2024, 06:46 AM
Hello Henry, its not about budget, its about will the available now bearings be better than a good used Porsche ones, I heard a lot of not so good stories about the newer Glyco bearings being not so consistent in terms of clearances. Unfortunately where I live it is impossible to find someone who can dry-film bearings.
-1987 928S4.
Old 02-18-2024, 11:17 AM
Inconsistent Glyco main bearing was during a transitional phase when Federal Mogal took over Glyco.
We aren't seeing any of those old issue at this time. The internet never forgets and generally never gets updated.
Henry Schmidt
Ph: 760-728-3062
Old 02-18-2024, 11:28 AM
It's a 914 ...
stownsen914's Avatar
Also, I thought the issues were mostly with rod bearings anyway?
Old 02-18-2024, 12:57 PM
This seems an opportune time to ask. A friend pulled apart an engine that was rebuilt and run maybe a thousand miles or so.. The mains have these marks on them.
What does this indicate?
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 02-18-2024, 01:14 PM
That looks like a set of the transitional main bearings. They looked like that when they were installed and the builder just missed it. When the white metal was applied, it disguised the surface inconsistencies.
Henry Schmidt
Ph: 760-728-3062
Old 02-18-2024, 03:11 PM
Thanks Henry.
The engine was disassembled for other reasons, but would the mains above, have eventually caused some sort of detrimental running condition? I suspect there are hundreds of engines driving around with these transitional bearings in them and one would never know, unless they pulled it apart.
Obviously, it's not good.
Always learning.
Old 02-18-2024, 03:17 PM
It's a 914 ...
What was the approx. time frame of the transitional period? I'm about to assemble an engine with "regular" Glyco bearings (seem to have a date code of 5/2019 and from Poland in case that matters), and now I'm wondering if they are OK.
Old 02-19-2024, 05:12 AM
Originally Posted by mikedsilva View Post
Thanks Henry.
As ugly as those bearings look, they probably wouldn't have caused a problem.
Simply polishing them gently, with a 600 grit wet/dry should make them usable.
A light polish and dry film coating and they are better than new.
Remember we're dealing with a 6 cylinder engine with 8 main bearing. A design that is really over the top.
I remember some Mercedes 6 cylinder engine with 3 main bearings.
Henry Schmidt
Ph: 760-728-3062
Old 02-19-2024, 05:19 AM
I would use the old trick of polishing them with a kitchen paper towel. It's really just cosmetic.
Old 02-19-2024, 07:52 AM
You can dry film them yourself,
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 02-19-2024, 07:59 AM
https://techlinecoatings.com.au/product/dfl-1-powerkote/
Old 02-19-2024, 08:10 AM
There can be a greater benefit to light sanding than simple cosmetics.
We have been sanding air-cooled bearing since the early 70s as a way to increase clearances on racing engines. It seems there can be a benefit to greater clearances combined with higher oil pressures. SOP on Chevy's I think?
The Nissan GTP engines I worked with went the other direction. They ran crazy tight clearances. The problem was, you had to heat the engine before you could start it up.
Doing it properly is not as easy as it looks.
It's more that clean and spray. It take an understanding of blasting, spray and drying techniques.
Of course it can be done but paying an expert may prevent the need to start over.
Henry Schmidt
Ph: 760-728-3062
Old 02-19-2024, 09:06 AM
Chain fence eating turbo
A long-time member here suffered that fate not that long ago. It is a nauseating situation.
It is still surfacing from some stock floating around, apparently.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 02-19-2024, 11:35 AM
You can get Chevy bearings in standard sizes and 0.001" over or under bearings and would use one of each half shell to get the right clearances. But Chevy bearings are a dime a dozen and available everywhere. Porsche, not so much so. Bearing clearances are determined (mostly) by the intended oil viscosity. Thicker oil requires added bearing clearances. In Cup, we were down to 0W-9 engine oil. Bearing clearances were just under a thousandth. Oil pressure was actually lower than Porsche engines.
I too have sanded the backside of the bearings to get the correct tolerances when no other option was available. You gotta do what you gotta do.
I'd send the bearings out for coating too. Leave it to the professionals that do it every day. No way that I'm experimenting on an engine that I care about.
Old 02-19-2024, 12:31 PM
Actually, the 996 GT3 bearings came in three different sizes. The crank journals are often marked with red, blue or yellow so that each journal can get the correct size. As far as I know, only the red bearing (largest clearance) are available.
As I've said before, the mains on a 7000 rpm air-cooled engine are not generally critical. proper clearance + is generally a good rule.
Henry Schmidt
Ph: 760-728-3062
Old 02-19-2024, 12:55 PM
Henry, others, FYI: Per Smokey Yunick's book, on his NASCAR Chevy engines, he wanted .0025-.0027" on the mains. He wanted to pump extra oil through the bearings to help keep them cool at 8000 RPM.
I'll note that the Tech Specs for the 3.0 SC and 3.3 Turbo engines allows .010mm to .072mm (.0004" to .003") on the 1-7 mains; and .03mm - .088mm (.0012"- .0035"), which seems like a pretty wide tolerance spread. I don't have one for the 3.2 engine handy, but I'll bet it's the same. "Proper clearance +" is a good rule.
Old 02-19-2024, 02:40 PM
On pull type clutches, you see wear on the thrust surface of the rear main bearing. If trying to reuse mains check axial crankshaft clearance and compare to specs. I check during disassembly to see where I’m at. Rare, but I’ve found crank thrust flange wear from clutch riding.
Old 02-20-2024, 08:28 AM
