UPDATE - '78 case built to '80 Euro, FD & WUR mess
Thanks for all the posts and help in May while I was trying to sort this. I decided that being this deep into it I wasn't going to cut corners and Frankenstein the top works. Located a complete '81 CIS that would match perfectly with my Euro 3.0 Mahle pistons. Drove out to S.A. and picked it up. Now the whole thing is compatible 80/81 Euro CIS, every part.
A few pics to show the result. Making plans for the next steps to stuff it in. Thank you for your comments. ![]() ![]()
78/79
Simply run 78/79 fuel distributor and wur . Get rid of the frequency valve if its on the later cis that your using . The earlier SC cis is the way to go and its a much easier application than using a later cis with lamda . Maybe get a better ignition as well and that engine should run strong . Cheers
PCA Member since 1988
He bought a complete Euro CIS. It doesn't have lambda control.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Sticking with what we built - basically a 100% Euro 3.0 but with a 964 Cam.
Looks good and expect it to run sweet in the ducktail. Last edited by jellonailer; 08-13-2024 at 01:26 PM.. |
From looking at your pics, you are missing a very important piece of tin ,
the back plate for cyl 3 and to the flywheel. Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
Probably because it's still on the engine holder.
And an oil return tube, etc. Missing a rebuilt 915 too.
